One piece tray wanted. 470cm * 50cm. Any material this long?
Hi All,
I’m fishing for advice.
One of potential customers wants a sign tray, 470cm wide 55cm high, 30cm returns (no return on the top- this goes to cover bottom and sides of a shutter box).
The issue is he did stress he does not want a joint anywhere on the face of the tray… Would it be possible to make such a tray and enamel it?
If yes, there will be few flatcuts to glue on top.
The tray will go flat against the shutter box, flush on the top with a ledge, to which an awning is bolted… there is no chance of any return on top, but all sides will be on VHB and screws on sides and bottom…
I do expect a sheet limit even on metal substrates… Problem is the client seems set in stone.Thanks in advance.
