Home Forums Sign Making Discussions General Sign Topics one of those days…
  • one of those days…
    Posted by Bart Van Wassenhove on 25 July 2005 at 13:53
    🙁 it’s one of those days…
    raining outside, thunder inside 👿
    I have a dibond 2mm panel 200x100cm that has be covered with an Oracal 751C/053 vinyl with some letters cut out. I don’t know what i’m doing wrong but it just doesn’t work 😥
    When i apply the vinyl (with my 3M gold-tool) i keep getting wrinkles 😳
    What am i doing wrong??? Or is it just me being clumsy 😳 🙁
    Ramj replied 20 years, 5 months ago 13 Members · 18 Replies
  • 18 Replies
    25 July 2005 at 14:09
    what way are you angling your squeegee mate?
    have you watched the video of me applying vinyl around 610 x 610 wide to aluminum? try using this method and you should be fine…
    751 is “cast” now so make sure the panel or the room is not warm or its gonna stick very fast.
    i prefer to wrap a bit of denim material tight around the edge of my gold squeegee. held in place with double sided tape. allows same pressure you get from nylon squeegees but less friction.
  • Bart Van Wassenhove
    25 July 2005 at 14:13
    thank you rob,
    i’ll try it later this afternoon. I just hope it makes a difference 🙄
    25 July 2005 at 15:37
    The humidity does have a big effect.
    If you can, wait for a drier day.
    We might get one come September.
    25 July 2005 at 15:43
    lol Jill, life looks so much better when wearing pink glasses…
    :pink: :pink: :pink:
  • Peter Shaw
    25 July 2005 at 15:54
    If you think humidity is the problem, why not lay it wet?
  • Kev Mayger
    25 July 2005 at 16:01
    You can also try leaving the letters in whilst laying the vinyl then weeding out the letters afterwards. I have found that this helps the vinyl from ‘twisting’ in between letters & reduces piping. Worth a go
    KM
  • Tim Painter
    25 July 2005 at 16:08
    Rob can you put the link in a post I can’t seem to find the video you mention?
    Tim.
  • drogers4
    25 July 2005 at 17:18
    I have not viewed the demo yet which Rob is mentioning (need to upgrade) but just recently I laid a vinyl print 4′ X 4′ on plywood and used application fluid and got no wrinkles or bubbles at all, when without the fluid I always had the same problem you are having, one wrinkle can ruin the whole sign, especially since it’s hard to confine the wrinkle, it usually runs all the way through the vinyl.
    I would try wet applying it and try what mayger mentioned about weeding out the letters afterwards. I never got good results doing large flood-coating until I used fluid, maybe it’s just me. Good Luck!
    Doyle
  • Chris Hooper
    25 July 2005 at 17:45
    As per Robs suggestion – reduce the friction.
    If you have some sticky velcro strip (furry part) cover one of your edges of squeegee with this. Or use sleeves.
  • Ramj
    25 July 2005 at 17:47
    I had one of those days last week, I was working on my own and I left a certain letter out of a safety sign too,
    I had no f-in staff
    25 July 2005 at 17:55
    Let’s all go out and have a cold one.
    I dunno about you, but I feel the need to get comfortably numb.
    Gonna put up the “closed” sign and have a Mental Health Day.
    (90º and 90% humidity here in PA)
  • John Singh
    25 July 2005 at 18:45
    quote :
    I had no f-in staff
    very good Ramj :lol1: :lol1: :lol1:
  • Ramj
    25 July 2005 at 18:53
    and 100% true too, the customer (thank god) was a regular and was obviously used to us messing up alot.
    I mean…
    our brilliant service had not previously been tarnished at all .
  • Paul Cox
    25 July 2005 at 20:31
    Ramj, where are you working? Are you based in Cardiff?
    25 July 2005 at 20:33
    quote Jillbeans:
    sounds good to me jill…..that’s my next excuse when everyone thinks i’m drunk :lol1: :lol1: 😉
    25 July 2005 at 21:14
    hehe, job well done. I did it wet (sooooorry rob 😳 ) and weeded the letters afterwards. Thanks evryone… 😀
    25 July 2005 at 21:33
    lol, i can relate, last week i was knocking up the 01’s and ‘general lee’ text for the dukes of hazzard charger kits, i made up enough bits for 5 pairs of each, on the 01’s i leave a large box around then that i use as a reg mark, i wet align the reg’s at one end and then apply down, same with the genereal le text,
    bugger me, major bad day, i considered only 2 pairs of 01’s to be worth keeping (each 01 layered. is 2m of material + tape) after having one with more bubbles than an aero candy bar, and more than i cared to bother trying with, two that somehow slipped and didnt then line up right, and three that ‘touched’ before they should have and stuck solid !
    then i find that the mate who made the general lee text for me (re drew it from a pic of an original) misplaced the reg marks and i ended up with only two out of 10 that were right, only cos i did them by eye !
    i’ve cut enough to finiish the sets now, but have decided to layer them when they’re sold rather than doing them all now, then at least if i mess them, i wont sem like messed so much inone go !
    never had a day like that before, hope never do again !
  • Ramj
    26 July 2005 at 22:25
    sorry to revive an old-ish topic,
    Cokka, I’m based in newport, are you in cardiff?
