Home Forums Vinyl Cutter Discussions General Cutter topics On the look out for a new cutter – Budget £400 for a new one
  • On the look out for a new cutter – Budget £400 for a new one
    Posted by Daniel Owen on 15 July 2011 at 14:40
    As my redsail is just a little too big to fit in my office I am after something smaller. No bigger than 640mm.
    Is there any decent ones out there for £400 new, which can cut 3mm letters with ease.
    Ideally one that will take roland blades aswell.
    Dan
    AtKo replied 11 years, 12 months ago 8 Members · 11 Replies
  • 11 Replies
    15 July 2011 at 15:07
    Unlikely you will find a plotter that will cut 3mm text with ease on the budget you have. For small text & intricate graphics plotters such as graphtec & summa work in tangiential mode. This isn’t available on the chinese plotters as it’s one of the functions they leave off to keep the price of the machines down.
  • Daniel Owen
    15 July 2011 at 15:10
    quote Martin:
    My redsail can cut 3mm letters quite well when using thicker vinyl.
    If I can’t find a decent second hand cutter nearby then I may just downsize to a smaller redsail.
  • Ian Johnston
    15 July 2011 at 15:40
    quote Daniel Owen:
    quote Martin:
    i assume you are talking about 3mm stroke width, not 3mm high letters,
  • David-Foster-
    15 July 2011 at 16:00
    quote Daniel Owen:
    Didn’t you say on another topic that "And if I cut anything below 10mm, i.e. small lettering it is just making a mess of it. "
    Just getting it straight how your redsail is in case you are selling it. Has the new cutting strip sorted it?
  • Daniel Owen
    15 July 2011 at 16:12
    quote David-Foster-:
    quote Daniel Owen:
    Didn’t you say on another topic that “And if I cut anything below 10mm, i.e. small lettering it is just making a mess of it. ”
    I need to replace the strip and holder and it should be cutting perfect again.
    And yes it was able to cut 3mm high letters before the current problem started happening.
  • Daniel Owen
    15 July 2011 at 21:06
    I’ve cleared some room in my office now to fit my redsail in.
    But I am now on the hunt for a desktop cutter.
    Can anyone recommend one
    And here is an example of the size my redsail can easily cut
    Not bad considering the cutter only cost me £450
    15 July 2011 at 22:57
    why do you need another plotter when the one you have does such a good job? or if you are really short of room, just buy a smaller redsail
    my mimaki will cut equally well small letters, but in practice why would I want to? any quantity of small lettering would make weeding not cost effective, so print would be a better way to go?
    peter
  • Robert Kulawik
    16 July 2011 at 10:27
    Eeehhh,
    3mm?
    2mm?
    It’s nothing compared to what my Graphtec does, and this is on the bad day…
    ..I’ll get my coat 😉
  • Daniel Owen
    16 July 2011 at 18:22
    quote Robert Kulawik:
    Eeehhh,
    3mm?
    2mm?
    Do you have to use a magnifying glass to weed that, lol
  • Daniel Evans
    16 July 2011 at 18:52
    My god that is good, What settings did you use to get that?
  • AtKo
    27 November 2013 at 11:00
    I see that this topic is a little bit old. But I will ask a question and hope to get answer 🙂
    @Daniel or someone else: you use Redsail and you said that you can easily cut 3mm high letters.
    What are proper settings for cutting so small, what kind of blade, offset etc?
    I can cut so small, but letters are cutted very very ugly 🙂
    Thanks for help.
