Home Forums Printing Discussions Roland Printers Not picking up pinch rollers help
  • Not picking up pinch rollers help
    Posted by Dan Osterbery on 13 August 2018 at 20:20
    Hello All, our 540sp versacamm has stopped picking up the pinch roller positions. Can anyone shed any light on which bit might be faulty? It started playing up last week, now wont read anything.
    Thanks in advance
    Dan
    Dan Osterbery replied 7 years, 4 months ago 2 Members · 4 Replies
  • Stafford Cox
    14 August 2018 at 07:08
    I’d look at replacing the cut cable and guides first. Fairly cheap simple to do and worth doing every so often as they are a common failure.
  • Dan Osterbery
    14 August 2018 at 07:22
    Thanks stafford! After hours of googling last night cut carriage cables and the pinch roller sensor seem to be the first two ports of call. Will get them ordered today.
  • Dan Osterbery
    14 August 2018 at 08:33
    Hi Stafford,
    ok i am about to order the following:
    31299102AS nylon rivet set
    22715463-00 cut carriage board
    23415119-00 cable Assy pinch sensor
    21655311-00 cable holders
    23475238-00 cable
    is there anything else i might need? I have printed the following sections from the service manual. 3-4 tool carriage replacement and 3-14 flexible cable replacement. I just wanted to check that i have the right parts and that i am looking in the right areas. Is there anything that is recommended to be repaced when i swap these parts? Would you suggest doing carriage cables first?
    thanks
    Dan
  • Dan Osterbery
    14 August 2018 at 09:35
    Here is the final order i think? Please let me know if anything missing.
    thanks in advance
    Dan
