Home Forums Sign Making Discussions Vinyl New to textile vinyl and need help please?
  • New to textile vinyl and need help please?
    Posted by bootyhunter on 18 March 2004 at 15:17
    I have just bought a Puma II cutter and got some textile PU vinyl to start making Tees. Problem is, when I heat press the stuff it does not peel. I have tried all settings, heat, time and pressure and still no luck, if I do pull hard enough the thing tears and I only get half my design onto the garment. This has happened with all colours apart from gold, which seems to be better.
    Can anyone help, am I doing something wrong or is it a dodgy bit of vinyl?
    Thanks guys,
    Dave Payne
    BootyHunter
    bootyhunter replied 21 years, 9 months ago 4 Members · 5 Replies
  • red dragon
    18 March 2004 at 15:30
    Does it say to remove backing hot or cold?
    If your trying to remove to soon/late this is what can happen.
  • Lorraine Buchan
    18 March 2004 at 15:49
    As Sharon says…. some materials are meant for hot peel and some for cold peel check with your supplier.
  • Kevin.Beck
    18 March 2004 at 17:41
    make sure the material you have bought, is for the garments you are using.
    I used material made for nylon garments, on cotton. The result was a pain to peel.
    check how much pressure you are busing to cut it. You only require just enough.
    Try using a scalple to tease the design away from the carrier.
  • bootyhunter
    19 March 2004 at 08:39
    Thanks for your help guys!
    I did follow the instructions and even played witht the settings, but still no joy. I now wonder whether the supplier sent the wrong type. I have sent an example of the garment and vinyl back to the supplier so they can do their own tests.
    I will let you know what what happens…
  • bootyhunter
    19 March 2004 at 12:56
    The PU material we have has a sticky carrier (ENVIRO). This normally is a
    HOT peel. However, most materials have a COLD peel. The material from
    Xpres is a cold peel and the one from Vic is a hot peel too. If its not
    peeling because the edges are ‘welded’ to the garment, then the reason is
    cutting too deep in the Mylar carrier, and/or you are using too much
    pressure with the heat press.
    Adjust blade to very lightly score the Mylar (very important) and then check
    your heat press for a lighter pressure.
