Home Forums Vinyl Cutter Discussions General Cutter topics New Plotter for 300mic Laminate
  • New Plotter for 300mic Laminate
    Posted by Joe Killeen on 16 June 2017 at 10:08
    Hi guy’s
    looking to upgrade our plotter, of late we are getting a lot of work using 300 micron laminate.
    We print with a Versacamm SP540i laminate back in to the versacamm and have cut at a force of 250 and 3 passes.
    I know this is going to damage the versacamm as it is not designed for this type of work.
    Our vinyl plotter is only 2′ wide so was thinking of changing it which would also help speed up workflow as the printer can print and the plotter can cut.
    My problem is too many to choose from so just wondering what you use and the pros and cons.
    Joe
    Chris Wool replied 8 years, 6 months ago 1 Member · 1 Reply
  • 1 Reply
    17 June 2017 at 06:15
    At those pressures and passes surprise you are not getting miss cuts and sounds like a flat bed could be a way forward
