Home Forums Sign Making Discussions General Sign Topics Need advice on what clear plastic to use?
  • Need advice on what clear plastic to use?
    Posted by Peter Coogan on 17 May 2013 at 17:43
    Have been asked to supply 20 pieces of clear plastic 18"x18" to cover operating instructions on some large exterior Generators approx 3mm thick
    he mentioned Perspex is their any other stratas that would do the job possibly a bit cheaper thanks
    Pete
    Peter Coogan replied 12 years, 7 months ago 3 Members · 4 Replies
    17 May 2013 at 21:04
    Polycarbonate is generally more expensive than acrylic so that rules that out, not sure there is really much else, also make sure you get exterior grade.
  • Peter Coogan
    18 May 2013 at 08:20
    Thanks for your help Martin
    Pete
  • NeilRoss
    18 May 2013 at 08:23
    Pete – Perspex is an ICI brand name for their own acrylic material. Personally I’d say the best, but also probably the most expensive. There are alternative brands of acrylic sheet out there (not all are colour fast – not important in your case) at less cost. A low cost alternative is styrene, but nothing like so good quality as Perspex/acrylic, and will more than likely craze in a relatively short time. Fine for cheap short term work though.
    Speak to your own suppliers about alternative makes of acrylic, or Google for ‘acrylic sheet’ and you’ll find some suppliers to talk to.
  • Peter Coogan
    18 May 2013 at 09:57
    Thanks Neil will take your advise I want the material I choose to last
    they are very good customers of mine
