Home Forums Vinyl Cutter Discussions Summa Cutters My Summa D60 won’t turn on
  • My Summa D60 won’t turn on
    Posted by Gary Birch on 3 December 2008 at 20:15
    Hi all.
    My Summa D60 won’t switch on. I have checked the obvious fuse in the plug and also the smaller fuse near the switch. Both are fine.
    Is there any thing else which I can look at?? or is it something major?
    Any help appreciated.
    Gary
    Gary Birch replied 17 years, 1 month ago 3 Members · 5 Replies
  • Karl Williams
    3 December 2008 at 20:34
    Is it totally dead? How old is it?
  • Gary Birch
    4 December 2008 at 08:42
    Karl
    Yes its not making a whisper and the display is blank. I have had it before but just changed the fuse.
    It’s about 4 years old now.
    We are in the process of moving premises so it might appreciate a ride in the van lol 😀
    Seriously I don`t have that much time to take a look at it now but just wondered if there was anything obvious I should be looking at.
    Gary
  • Tim Painter
    4 December 2008 at 09:24
    If your competent Gary check and see if you are getting mains to the power supply. If that’s all OK it sounds like the power supply is dead or possibly just one output maybe just the 5Volts.
    If you find this to be the case give me a nudge as I have a decent co who most likely can repair the supply at very good prices with great service.
    Tim.
  • Karl Williams
    4 December 2008 at 09:38
    On the back of the switch check to see if the wire is connected to the switch. It should just be a slide in connection. If it looks ok still disconnect it and then reconnect. The vibration of the machine can cause these to come undone or to result in a poor connection.
    Worth a try. 😉
  • Gary Birch
    4 December 2008 at 10:21
    Karl
    Its in the back of the van mate but when I get it out I will try this and let you know how I get on.
    Thanks very much for your help its much appreciated.
    Gary
