Depends on the format and the machine its being printed on , vector format should always print perfectly unless the machine messes it up.
Raster output for far viewing needs to be sent at about 75 pixels per inch of printed output. IE if you are printing 20″ x 30″ , you need to send a 1500 x 2250 pixel file for it to print really well. The DPI is totally irrelevant , it’s the size that counts.
Be careful of colorspaces , your screen is an RGB device and the printer is a CMYK and the colors you see on an uncalibrated screen will differ markedly from what you see in print. If you are using Corel , use color management to emulate professional CMYK output to see what you will get (more or less)
Be careful of Vector based fades too , some printers and RIPS dont handle them well and you can get a pronounced banding effect in the fade. Ask your printer how his machine handles them, sometimes its better to convert a vector fade (like a corel radial fill etc) into a bitmap.
Be aware again that bitmaps can get reproduced very dull if you send a RGB bitmap and the printer converts it to CMYK , ask the printer whether he wants bitmaps sent as CMYK or RGB.
CMYK cannot reproduce the brightness and color gamut etc you see on screen.
