Home Forums Vinyl Cutter Discussions Mimaki Cutters mutoh vj-1604 ink problem
  • mutoh vj-1604 ink problem
    Posted by anton hughes on 15 February 2012 at 12:30
    HI i’m new to this forum and was wondering if sum1 could help me.
    i am currently using 440ml ink cartridges in my mutoh and when the machine is telling me they are empty i am changing the cartridges but when i open the cartridge up it is still half full is there anyway of changing this.
    anton hughes replied 13 years, 10 months ago 4 Members · 4 Replies
  • Neil Davey
    15 February 2012 at 13:14
    Hi Anton, if you introduce yourself in the Welcome Forum and tell us a little about yourself you’ll probably get a few answers to your problem.
    Neil
  • Stafford Cox
    15 February 2012 at 14:17
    Hi Anton.
    Try looking up where the cartridge goes and compare the faulty assembly with one that’s working and you’ll probably find that one of the triggers has bend backwards and isn’t able to read the tab on the cartridge that presses out as the tab comes out. It’s not an expensive part to replace but it can be quite tricky to get to. I’ve not done one on a 1604 but I have on Mimaki’s and Roland’s.
    Let us know how it goes.
    Stafford
    15 February 2012 at 14:38
    are you spirit level square with the printer?
  • anton hughes
    22 February 2012 at 10:05
    thanks for the advice the printer was not sitting square so hopefully that will be it sorted thanks.
