Home Forums Vinyl Cutter Discussions Mimaki Cutters mutoh sc 650 carriage head hitting side
  • mutoh sc 650 carriage head hitting side
    Posted by graham sanson on 12 August 2011 at 10:15
    hello there.
    i have a issue with my mutoh 650, when i switch it on the head first moves to the right hand side of the machine and actually hits the side of the inside casing. then it continues to read the size of the vinyl, is this because of the machine or i suspect some software setting, im using flexi sign 8.
    any suggestions would be great.
    thanks graham
    jimmy replied 14 years, 4 months ago 3 Members · 4 Replies
  • jimmy
    21 August 2011 at 19:32
    sounds like your linear encoder is dirty, its happened to me in the past and after cleaning it the problem was solved.
  • graham sanson
    21 August 2011 at 19:36
    linear encoder? whats that? and how do i clean it?
    thanks for the response
    regards graham
    22 August 2011 at 01:02
    Don’t know what sort of set up the Mutoh has but these problems can also be caused by the head position sensors not functioning correctly.
  • jimmy
    22 August 2011 at 16:50
    If you google
    mutoh linear encoder , it will give you all in the information needed. As for cleaning, one should note that extra extra care should be taken when cleaning, usually a good wipe with a damp cloth ( cooton no hard surface ) , but you should also contact your local dealer for further information.
