Home Forums Printing Discussions Mimaki Printers Mimaki TPC 1000 – Need help please?
  • Mimaki TPC 1000 – Need help please?
    Posted by Bekarion on 22 March 2011 at 06:50
    Hello,
    We got a brand new Mimaki TPC1000S sublimation printer cutter.
    All was done as required. Machine converted form Eco Solvent to Sublimation printing as per requirements described in the manual.
    Inks and cleaning went all perfect. test printing is also just fine, but while printing there is a some kind of a mismatch.
    Can you please advice how to fix the problem?
    I have purchased it from Turkish Dealer and tried to call them and mailed them several times, but they are like does not hear. Contacting Mimaki Europe and they are redirecting me to the dealer. I am in the between and without any support.
    can anybody help to fix the problem please..
    attached the photo.
    Justin Atkinson replied 14 years, 9 months ago 4 Members · 6 Replies
    22 March 2011 at 09:46
    at first glance i would say poor artwork. (ghosting and pixels )
    draw some squares triangles and circles fill with different colours and retest
  • Bekarion
    22 March 2011 at 10:25
    [quote="Chris Wool"]at first glance i would say poor artwork. (ghosting and pixels )
    draw some squares triangles and circles fill with different colors and retest[/quote]
    You are right –
    i have tried circles, triangles, text. and the same.
    later I have just sent Uni direction printing and all went well.
    It happens only when bi direction i s sent.
    I believe need some adjustments
    22 March 2011 at 14:47
    i did think about the bi directional printing but could not believe it could be that far out.
    there is a routine to run on the printer to reset the bi dir print alignment.
    22 March 2011 at 15:06
    without a doubt, bi-directional alignment
    22 March 2011 at 15:07
    if the heads are up a fair way for thick materials, it will cause this…
    i dont have this machine btw… only the mimaki jv3 which i know suffers from changes in thickness
  • Justin Atkinson
    23 March 2011 at 23:36
    As you are all saying…. BI-DI 100%
    Thanks,
    Justin
