Home Forums Vinyl Cutter Discussions Mimaki Cutters Mimaki Software Problem – help installing please?
  • Mimaki Software Problem – help installing please?
    Posted by Marcus O'Neill on 29 January 2015 at 11:33
    Hi all, I have recently bought a Mimaki JV3 SP2 printer & a Mimaki CG 130FX Cutter second hand off a neighbouring sign company. I have a problem getting the software installed.
    I now use windows 7 so the Mimaki software & drivers were windows 2000/XP! I have downloaded the proper drivers from the Mimaki web site but the computer still wants me to insert CD ROM which is out of date???
    The RIP software that came with the printer is SHIRAZ V6 but its for windows 2000/XP too!!!!
    I currently use Signlab 7.1 which should run the printer??? Has anyone got any ideas what to try??? Thanks Marcus.
    :banghead:
    Marcus O'Neill replied 10 years, 11 months ago 3 Members · 14 Replies
  • 14 Replies
  • Jon Marshall
    29 January 2015 at 11:40
    Have you got a separate RIP PC? Might be worth just getting one and sticking WIn XP on it. We do the same with Shiraz.
  • Marcus O'Neill
    29 January 2015 at 12:29
    Hi Jon,
    Thanks for the reply. That might be an idea as I have a spare pc with windows XP Professional installed on it.
    How does that then be linked with the other system….Networked?
    Cheers!
  • Stafford Cox
    2 February 2015 at 14:23
    I can help you with all things Shiraz as I am a reseller.
    What version are you running? If you click on the ‘about’ button in either Server or Design, it will tell you a version (v6.x) and a build number (bxxxx). Let me know what they are and I should be able to advise you.
    Stafford
  • Marcus O'Neill
    2 February 2015 at 15:22
    Thanks Stafford, I just got the original XP PC from the sign company and everything is still on it so problem solved!!! 😀
  • Stafford Cox
    2 February 2015 at 15:50
    Great stuff.
    If you have any further questions or problems, just post up a again and I’ll try and answer.
    Stafford
  • Marcus O'Neill
    2 February 2015 at 17:22
    Cheers! That will be great as I am new to Shiraz! :thumbup2:
  • Stafford Cox
    2 February 2015 at 17:46
    These might be of use then…..
  • Stafford Cox
    2 February 2015 at 18:02
    ….and finally, Server.
  • Stafford Cox
    2 February 2015 at 18:06
    Sorry, the PDF for Design is too big to upload 🙄
  • Marcus O'Neill
    3 February 2015 at 09:51
    Thanks Stanford,
    Can you send by – Mail Big File? (web mail)
  • Stafford Cox
    4 February 2015 at 20:57
    I’m not sure I’m allowed to do that to be honest.
    The manuals should be in your installed version anyway, under Shiraz\doc\en (if you want English)….
  • Marcus O'Neill
    5 February 2015 at 01:21
    I will check this out Stanford
    Cheers again! 😀
  • Stafford Cox
    8 February 2015 at 17:39
    Did you get the manuals Marcus?
    Just to keep this post up to date, all manuals for Shiraz v6.x can be found in the installed folder:
    C:\Program Files (x86)\Shiraz v6.x\Doc\
    Within that folder you have the following languages:
    DE = German
    EN = English
    ES = Spanish
    FR = French
    IT = Italian
    Stafford
  • Marcus O'Neill
    16 February 2015 at 16:18
    Thanks Stanford,
    Problem was solved by the seller giving me his XP pc. The software was already installed on it!
    Thanks for your help!
    Marcus 😀
