Home Forums Vinyl Cutter Discussions Mimaki Cutters Mimaki JV400-130/160LX latex Printer
  • Mimaki JV400-130/160LX latex Printer
    Posted by Andre Woodcock on 15 February 2012 at 04:32
    I’ was about to add a New HP L26500 Latex printer to my setup and this morning I received a message on the upcoming Mimaki JV400-130/160LX latex Printer.
    If anyone of you guys have pros and cons on both of the above printers Please help.
    Many Thanks
    Andre
    Gary Barker replied 10 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
    15 February 2012 at 04:39
    i only just found out about it a day or two ago andrew, think it will be some time before the real pro’s & con’s come about. I plan having a look at sign + digital next month when i’m down.
    would be interesting if they incorporate print and cut with it too… 😀
    15 February 2012 at 12:03
    hi yes we started talking about it
    We cannot confirm the heads in the machine but we think it is engineer call out based, quite possibly the same heads as mimaki flatbeds.
    The width is wider 1.6mtr
    The heaters are working at 60deg, so banners should be ok.
    It be just like normal Mimaki stuff.
    We are really pleased with the maintenace side to the HP Latex.. still think it is the best out of the bunch
  • Andre Woodcock
    15 February 2012 at 12:59
    Thank you for your feedback Rob and Dave.
    I’ve got a good deal on a HP DJ L26500 from one supplier and also on a demo unit HP DJ L25500. Have you compare those 2 printers yet?
    Andre
  • Stafford Cox
    15 February 2012 at 14:23
    As Dave says, it’s going to be very similar to Mimaki’s of the past where the head is a fixed Piezo. My guess is it will be a Toshiba CA4W like the JF/X and Xaar fladbeds.
    My thoughts would be that it will be a very good machine and probably will come with a 2 year warrantly (1st from Mimaki, 2nd from Hybrid direct).
    It’s only been announced in the last couple of days so it’s new to us all so time will tell how good or bad it is…..
    Stafford
    15 February 2012 at 14:36
    Andre…
    L25500 brilliant machine but if you want to do banners then the newer l26500 well make it easier.
    Basically the ink is lower cure on the new one which is a big difference.
    The new one is better for fabric handling
    Double sided banners..
    Youtube/isigntube has lots of videos
  • Fabrice Menard
    15 February 2012 at 14:49
    quote Dave Rowland:
    I read that it could be Ricoh printhead (2 heads on the machine), of course it was only a rumor.
  • Gary Barker
    6 August 2015 at 15:40
    Hi All has anyone got one of these printers ? pro’s and con’s pls
    Gary
