Home Forums Vinyl Cutter Discussions Mimaki Cutters Mimaki JV33 pop-up material drifting problem!
  • Mimaki JV33 pop-up material drifting problem!
    Posted by Paul Wood on 5 February 2010 at 09:35
    Does anyone have a media drifting problem when using pop-up media?
    We’ve tried different medias (PVC / Polyester) to no avail!
    Any ideas to why it only happens with pop-up media on long runs, say a 3×3 bay.
    We use the take up reel, by the 4th panel it’s drifted over as far as 1" in some cases which causes the finished panels not to line up!!!!
    Hybrid have been in to check the machine, they say all is good so we are very puzzled at the moment?????
    budone replied 15 years, 10 months ago 4 Members · 4 Replies
    5 February 2010 at 09:45
    So if you put a spirit level on the printer top, then the roll at the back when its on the machine and then the take up holder roll, you can confirm that all the measurements are spot on level?
    5 February 2010 at 10:03
    is it the media that has moved sideways or the print has shifted but the media stayed in alignment.
    welcome by the way
  • Paul Wood
    5 February 2010 at 10:14
    Hi Dave the level is slightly out so will adjust it, thanks.
    Hello Chris it’s the media moving, cheers
  • budone
    4 March 2010 at 10:01
    I have exactly the same problem on a JV3-160SP Using Metamarks MD PU2 pop up polyester… Will check to make sure its o the level.
