Home Forums Printing Discussions Mimaki Printers Mimaki JV3 cartridge not recognised
  • Mimaki JV3 cartridge not recognised
    Posted by John Thomson on 24 April 2013 at 12:40
    this morning when I switched on my JV3 I get a cart error…..it is not "seeing" one of the yellow carts.
    It is fitted with a bulk ink system and permanent chips…..I switched chips between the yellow carts and the same position is not recognised so I know it is not a faulty chip, I also inserted a spare cart with the chip fitted and same thing.
    When you slide the cart in or out there is a spot where you can see the cart being read but no amount of minute movements get it in the correct position.
    Anyone else had something like this?
    Many thanks
    John Thomson replied 12 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • John Thomson
    24 April 2013 at 19:13
    I emailed the company that manufactures/sold me the chips……got a quick reply asking for photos of the error messages……..duly sent so we will see what the morning email says.
  • Mo Gillis-Coates
    26 April 2013 at 06:28
    Daft idea, but have you tried rebooting the printer?
  • John Thomson
    26 April 2013 at 07:30
    Thanks Mo…..yes switched it off, dissconected the power lead…….then turned on to drain any power left in it.
    Chipemulator who provided the chips think it is the cart connection at fault so will have another look at it today.
  • Mo Gillis-Coates
    26 April 2013 at 07:49
    I had something similar with a Roland machine, but he reverse. When I tried to flush, the machine wouldn’t recognise that I had taken the cart out, it kept asking me to remove it. Thus out there was a pin that got pressed when you put the cart in, and it had stuck in the cart in position, ie permanently pressed in.
    I had to take the cart assembly apart and free it up.
    Although your problem sounds more "electronically " based. Maybe a cracked circuit solder on the chip reader?
  • Stafford Cox
    27 April 2013 at 18:33
    You could try bending the pins on the chip reader out John? That helps sometimes…
    Stafford
  • John Thomson
    28 April 2013 at 09:48
    put an original cart in to keep it running for now………this works OK…. so either the chip or the bulk cart are at fault.
  • John Thomson
    16 May 2013 at 09:36
    I got this sorted 😀
    The issue was that the contact between the printer and the cart was poor…..I cut a little spacer from 1mm hips plastic, slotted it in behind the chip on the end of the cart and that fixed it.
