Home Forums Printing Discussions Mimaki Printers Mimaki JV3-130 Black not printing correctly,need help :)
  • Mimaki JV3-130 Black not printing correctly,need help :)
    Posted by Adam Ali on 6 May 2016 at 08:23
    Hello there, I was wondering if anyone can help or offer advice. I have a Mimaki JV3-130SPII, however recently it hasn’t had much use and the problem I have is that when you do a test draw, the black head only outputs a partial print, of the 8 lines it prints part of the first 4 only. I have attached an image of this. I have cleaned around the edges of all the heads, done many cleaning cycles including nozzle wash, disway and custody as well as soft, normal and strong cleaning cycles. Despite that I am unable to get the black nozzles fully firing. Any help would be greatly appreciated.
    Many Thanks
    Adam.
    Adam Ali replied 9 years, 4 months ago 2 Members · 4 Replies
  • Stafford Cox
    6 May 2016 at 09:55
    Hi Adam.
    When you do a nozzle wash, does the solution stay in the black cap or drain away immediately?
    Stafford
  • Adam Ali
    6 May 2016 at 15:23
    It did drain away immediately, I noticed the tube connecting underneath the cap was loose so have re-attached the tube and now the liquid stays in the cap. I just did a test draw and presto 90% of the nozzles are back 🙂
    MANY MANY thanks for pointing that out. God bless you!
  • Stafford Cox
    10 May 2016 at 09:28
    No probs, glad I could be of help.
    Stafford
  • Adam Ali
    30 August 2016 at 14:16
    Hello Stafford, that same problem has come back but this time there is no black coming through at all. Any ideas?
