Home Forums Printing Discussions Mimaki Printers Mimaki cutline accuracy issue
  • Mimaki cutline accuracy issue
    Posted by Richard Thompson on 15 April 2013 at 22:25
    I have a CJV 130 with a problem when it comes to cutting an accurate cutline when vinyl has been returned to the printer once it has been laminated.
    1. i am cutting around shapes and it leaves the white of the vinyl showing, it needs to be cutting right on the edge of the colour?
    2. I am using rasterlink and i create the cutline using the extraction tool within finecut.
    has anybody got a solution to my problem? Just need to get the machine to cut on the edge of shapes without and colour of the white vinyl showing.
    Richard Daniel replied 12 years, 7 months ago 3 Members · 3 Replies
    16 April 2013 at 08:15
    too many reasons to list need more information,
  • Jon Marshall
    16 April 2013 at 09:23
    Unless you’ve added some bleed to the edge of your graphic then its always going to be an issue. Only has to be a tiny bit out (which it often is) and you’re going to see some white.
  • Richard Daniel
    15 May 2013 at 16:03
    I usually set up a complete block of colour where the text should be to avoid any issues.
    Its around images I struggle.- Once I received some artwork that had a fuzzy bleed around it meaning if the plotter ran off a little it still picked up the correct colours from the Jpeg. – never been able to crack it tho…
    Uploaded with ImageShack.us
