Home Forums Vinyl Cutter Discussions Mimaki Cutters Mimaki CG-160FX cutting alignment problem
  • Mimaki CG-160FX cutting alignment problem
    Posted by Kev Mayger on 16 January 2014 at 11:36
    Hi everyone
    I have printed some small decals on an HP Latex printer c/w hidden cut paths.
    The problem is when I send these to cut the accuracy is off by approx 1.5mm
    Now bearing in mind the decals have an even border all round they look $hit!!!
    Any ideas?
    Stafford Cox replied 11 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
  • Stafford Cox
    16 January 2014 at 11:50
    Hi Kev.
    Is it out by 1.5mm all round or in a single direction? It can only be a setup or calibration problem in my opinion, those things hardly ever go wrong.
    Stafford
  • Kev Mayger
    16 January 2014 at 11:52
    Stafford
    The cut path is approx 1.5mm lower than it should be.
  • Stafford Cox
    16 January 2014 at 11:55
    OK. When you set it to TP1 and let it go and pick up the register marks, does the blade end up EXACTLY on the corner point of the marker or is it 1.5mm out at this point?
  • Kev Mayger
    16 January 2014 at 11:57
    It sits bang on the marks
  • Stafford Cox
    16 January 2014 at 12:00
    Hmmm. Have you tried offsetting the job by -1.5mm in that direction in FineCut? I’ve got a couple of useful PDF files I can email to you if you’re struggling. Get in touch if so and I can send them to you….
    Stafford
  • Kev Mayger
    16 January 2014 at 12:58
    Hi Stafford
    I have emailed you.
  • Stafford Cox
    16 January 2014 at 13:50
    I’ve not seen anything Kev. Let me know your email address or send your details to:
    Stafford@atlantic-ts.com or
    Stafford@nds-services.co.uk
