Home Forums Sign Making Discussions File Swapping Microsoft Visio – File conversion
  • Microsoft Visio – File conversion
    Posted by Phill Fenton on 1 October 2007 at 12:05
    I have been given a microsoft visio file to print for a customer – can anyone convert this to a format I can put to my troop rip (e.g pdf).
    I’ve never heard of visio before today.
    Just discovered , the file extension is .vsd which is not recognised on here .
    Any suggestions 😕
    Phill Fenton replied 18 years, 3 months ago 4 Members · 6 Replies
  • George Elsmore
    1 October 2007 at 12:09
    zip it up Phill and post it to see if it can be converted
    1 October 2007 at 12:15
    OK – I’ve managed to zip it up (along with a low res pdf of the file that I managed to create myself – the pdf included here is no good to use as the resolution is very poor. I need to print this off at 610mm x 840mm
  • Brad Mulock
    1 October 2007 at 12:51
    Hi Phil,
    You can download a trial copy of Visio here
    http://office.microsoft.com/en-gb/visio/default.aspx
    Should be able to open the drawing then print to pdf. Visio as i remember it is vector based so resolution shouldn’t be a problem.
    I used to use it for network and topology drawing in a previous life. No longer have it installed or i’d of converted the file for you.
    Hope this helps
  • George Elsmore
    1 October 2007 at 12:59
    Sounds like the best route Phill, i thought i had visio but i do not and tried other programmes but getting no joy
  • John Childs
    1 October 2007 at 14:51
    Nothing I’ve got will look at it. 🙁
    1 October 2007 at 15:12
    Problem solved – the customer managed to create his own pdf for me to print from.
    Thanks for your help anyway guys 😀
