Home Forums Vinyl Cutter Discussions Mimaki Cutters Miamki cg130 fx cutting problem
  • Miamki cg130 fx cutting problem
    Posted by Steve Warburton on 21 October 2010 at 11:46
    Our plotter has spent the last few years doing mainly 600 X 400 square signs and a few small simple sticker jobs.
    We are producing a smallish sticker and am getting a snag on the corners.
    speed is 25
    pressure 180
    offset 30
    we have replaced the blade with new.
    The blade is in the inner holder.
    We are trying to cut the sticker so it drops out (no weeding). We have deleted a couple of small areas of the line if we don’t the vinyl just kinks and stops the job.
    PS what is the purpose of the outer holder.
    SteveW
    Stafford Cox replied 15 years, 2 months ago 3 Members · 5 Replies
    21 October 2010 at 13:39
    the pupose of the outer holder is to do this very action. it has a softer cutting strip so the blade should last longer
    you need to set up the half cut function either on the plotter or in the rip.
    The half cut function leaves a small tab olong the cut line so the decal can be pushed out easily
  • Steve Warburton
    25 October 2010 at 09:08
    Thanks for the info. Working a treat now we know what we are doing……….
  • Stafford Cox
    4 November 2010 at 14:01
    I have a print and cut ‘how to’ PDF that I made a couple of years ago if you need it? It is based on the Mimaki CG-FX plotter and Finecut software.
    Stafford
  • Steve Warburton
    4 November 2010 at 14:09
    We solved the problem once we realised we were working the worng way round for 3 years
    The PDF would be great.
    parkforce@googlemail.com
  • Stafford Cox
    4 November 2010 at 14:14
    quote Steve Warburton:
    Good stuff. Well done to Peter on that one then. I’ll send you the PDF over this afternoon.
    Stafford
