Home Forums Software Discussions Signlab Software Message ‘not enough memory for the bitmap’ ??
  • Message ‘not enough memory for the bitmap’ ??
    Posted by Phil Veitch on 22 September 2010 at 10:41
    We have had this problem for a while, we are using 7.1 print and cut, when trying to output to pint and cut manager we keep getting this message, then the program closes..
    Any suggestions as to why, the print is a gray fade and I’ve set a profile in signlab and it prints this fade great, but in versaworks I’ve not played with anything and the pint is pants..
    Thanks in advance
    Phil
    Gavin MacMillan replied 15 years, 2 months ago 4 Members · 8 Replies
  • 8 Replies
    22 September 2010 at 10:45
    your poor pc is suffering…
    post spec please
  • Phil Veitch
    22 September 2010 at 11:02
    should be fine..but..
    AMD Athalon 64×2 Dual
    Core processor 5000+
    2.60GHz, 3.25gb of ram
    with another hard drive to save onto..hope this helps
  • Gavin MacMillan
    22 September 2010 at 11:04
    We mainly get this is we set up duplicates in signlab, if possible repeat in P&C. Also rotating bitmaps causes issues, again if possible create in the graphics in the orientation you want to send them to the printer.
    G
  • Phil Veitch
    22 September 2010 at 12:30
    thats the exact problem we have with it..
    22 September 2010 at 12:38
    Phill
    it was a problem with signlab, but has been improved with SL8.
    How big is the image?
    You may be able use the link facility to get round some of the issues,
    and Like Gavin says do repeats in the rip, not in sigmlab itself, you will need to rip to file first though, if it is a print and cut job, before you can do repeats
  • Phil Veitch
    22 September 2010 at 12:40
    Thanks for that, was just trying to save some vinyl..lol..thanks guys
  • Phil Veitch
    22 September 2010 at 12:50
    AArrgh..right done all that ripped first etc a;ll set up fine, then when i press print it then fails..??
  • Gavin MacMillan
    22 September 2010 at 12:59
    what was the error when it failed to print? Shouldn’t be memory after it has ripped. I think you may need to be methodical and eliminate things like cut lines, fades etc. certain design items can cause errors. Can you maybe post an image of what you are trying to print?
    If it is still a memory problem, shut down your computer completely, not restart, then try again when it boots up without opening any unneeded software.
    Edit – another thought, if you also have a dedicated rip like versaworks, just publish your file as a high quality pdf and print from there, has gotten us out of many a jam. Done this way all your cut lines and everything should work without any messing around.
    G
