Home Forums Sign Making Discussions General Sign Topics Material Help please
  • Material Help please
    Posted by Warren Beard on 12 October 2007 at 14:59
    Hi Guys
    Customer has changed his mind and wants these flat cut letters and not raised stand off letters but he wants them this thick. I can only find 19mm thickness maximum in my price lists.
    Does anybody know who cuts letters out of this thickness foam (look like it is about 25 – 30mm)
    Warren
    Fred McLean replied 18 years, 2 months ago 5 Members · 9 Replies
  • 9 Replies
  • James Martin
    12 October 2007 at 15:05
    This mob do polysterene with a hot wire
    http://www.hampshireinsulations.co.uk/gallery.php
    This crowd you have to talk to for the thicker stuff, I was told, but I havent got roung to it yet.
    http://www.fabricut.co.uk/adpage.html
  • Warren Beard
    12 October 2007 at 15:07
    Looking at that I would say it is MDF 25mm, doesn’t polystyrene have a rough holey texture?
  • Steve Underhill
    12 October 2007 at 15:09
    Arent they just 10mm letters stuck together?
    Its quite a common way to get the thickness you want.
  • Warren Beard
    12 October 2007 at 15:12
    No Steve
    The edges are far too perfect for that, this is a new sign put up about a week ago so it looks prefect at the moment and can tell you the edges are smooth and solid.
    very much doubt it is 2 glued together
    Still think it must be MDF
  • Steve Underhill
    12 October 2007 at 15:21
    If its 2 glued together and finished correctly you shouldn’t really be able to tell if it is or not, depends who cut it with what, but Ive seen letters built up that couldn’t be distinguished from straight cnc cut letters if done right, especially if coated/painted.
    If you have seen them up dead close and there’s no visible join then they either are the latter or maybe mdf or injected.
  • Russell Spencer
    16 October 2007 at 09:01
    I think these guys are quite a big chain, so they may be resin cast letters (from a mould). I have seen them only briefly and they do look good.
    edit – isnt that a photocell on the first picture, if so the sign might be illuminated (letters only by the look of things) if thats the case then they will have to be built up acrylics
  • Warren Beard
    16 October 2007 at 09:34
    Hi Signsurfer
    No, def not illuminated as I have had a real close up look, I would almost put money on them being MDF.
    I have since found a supplier of 25mm foam PVC, cheaper than MDF but still very expensive 😕
    up to the customer now.
    Warren
  • Russell Spencer
    16 October 2007 at 12:47
    Warren,
    I have posted before about finishing the edges on foam pvc letters, the problem is that the routers will not/cannot cut through in one pass and has to step down 10mm at time which results in a stepping on the side of the letters, then you have the problem of sealing the edges, if you dont the paint is just soaked up, coat after coat and leaves a poor finish on the edge, we had some reasonable results last time by wiping the edge with a cloth soaked in cellulose thinners, it helped but it was far from perfect.
    good luck, let us know how you go on.
  • Fred McLean
    16 October 2007 at 13:07
    spandex do stuff called SIGNROC it’s polyurethane in 20mm or 40 mm
    thick softish but paints excellent you can even wire brush it to give a wooden effect or ball pein it to give a hammer finish etc. etc the only down side it aint cheap 😮
