Magnetic vinyl on a hot surface
I have to make a sign that fits on the front of a machine that the surface gets fairly hot. Not hot enough to burn you but hot enough to give you a shock if you hadn’t expected it. I cant screw a sign to the front so have two choices that I can think off.
1. Dibond sign bent at the top about 6" to a right angle and left just to hang over the front of the unit.
2. Magnetic panel stuck to surface.
Would the magnetic take the constant heat and would the vinyl stuck to it be affected in the long run?
Has anyone had any experience in this area!
