Home Forums Sign Making Discussions General Sign Topics Magenta line around blue prints on vp540
  • Magenta line around blue prints on vp540
    Posted by Jonathan feeney on 11 March 2018 at 12:16
    Hi everyone ,
    Looking for some help I run a Roland Vp540 and every time I print anything blue a magenta one appears around the image or lettering has anyone ever seen it or can anyone help
    Jonathan feeney replied 7 years, 9 months ago 7 Members · 15 Replies
  • 15 Replies
    11 March 2018 at 12:18
    is it somehow a ‘cutline’ path added by the rip?
  • Jonathan feeney
    11 March 2018 at 12:19
    Hi Hugh I’m not sure it is set to print only and you can only see it on one side of the letters haha I’m stumped
    11 March 2018 at 14:45
    quote Jonathan feeney:
    hmm, stumped me then, have you tried running head alignments etc.?
  • David Stevenson
    11 March 2018 at 15:30
    I’d be inclined to agree with Hugh. Looks like the heads need aligned
  • Jonathan feeney
    11 March 2018 at 16:42
    Is that an easy procedure ?
  • David Stevenson
    11 March 2018 at 20:37
    In all honesty it’s never a thing I’ve had to do. Any alignment I’ve done has been print and cut alignment. Have you tried cleaning the heads / encoder strip? Here’s link to the user manual although you possibly already have it –
    https://www.manualslib.com/download/960 … -Versacamm
  • Kevin Flowers
    11 March 2018 at 21:23
    Before you do a head alignment have you done a bi directional alignment which should be detailed in your owners manual but have attached a PDF, actual head alignment normally only needs doing on head replacement or a very severe head strike.
    http://support.rolanddga.com/docs/docum … _rev_1.pdf
  • Shawn Bentley
    12 March 2018 at 08:27
    Looks like a cut line added that’s not in the correct spot colour for cutting and printing the pink instead ? I’ve seen that before when I’ve added cut lines and not correct spit colour? although does look more of shadow than outline when zoomed in.
  • Jonathan feeney
    12 March 2018 at 08:29
    Thanks everyone the thing that’s annoying me is it only happening with blues
  • Peter Johnson
    12 March 2018 at 12:40
    That definitely looks like an alignment issue. Whether it’s the printheads or that ‘bi-directional’ alignment I couldn’t say, but I’d try the easiest/cheapest one of those options first and then the other if that fails.
  • Stafford Cox
    13 March 2018 at 23:56
    Definitely head alignments. Has it had a knock? Can you post a picture of the nozzle test? I might be able to tell you which head and which alignment.
  • Jonathan feeney
    13 March 2018 at 23:59
    Hi Stafford it’s not been knocked well not that I’m aware of , it’s been like this since I Got It so it may have been whilst in transit but it’s annoying now haha I’ll post a pic tomorrow cheers
  • Jonathan feeney
    14 March 2018 at 12:27
    Stafford this is the test print cheers
  • Stafford Cox
    14 March 2018 at 15:20
    Well that LOOK to be mechanically aligned so I would suggest the BIAS adjust doesn’t need to be altered although all 4 heads show signs of deflections, maybe you have an electrical fault with the cyan head? Have you tried printing at different resolutions? Ie production instead of quality etc.?
  • Jonathan feeney
    14 March 2018 at 15:27
    I’ll give it a go mate
