Activity Feed › Forums › Sign Making Discussions › General Sign Topics › Looking for some advice on removing a 3M wrapping vinyl?
Posted by Mark Piddington on December 30, 2019 at 3:18 pmHey, I hope everyone is enjoying the xmas break! I’m looking for some advice on removing some wrap media. I’ve been asked to strip and re-wrap a few vans for a customer, one of the vans we wrapped in Avery 1105 previously and is removing very nicely, another van was wrapped by a different company in 3m media and it is being a nightmare to remove, not the installers fault as it is very nicely fitted but the laminate is seperating from the media when we try to remove it leaving a very thin layer of wrap media that is just removing in small chunks. Another of the vans also wrapped in 3m the laminate has come away from the media in small chunks leaving the print to fade or wear away! Has anyone come across this issue before? Can anyone advise of a quicker way to remove the wrap? I will try and add some videos to show the issue
Thanks and happy new year to you all
Robert Lambie replied 4 years, 4 months ago 6 Members · 14 Replies -
Who has provided you with the information that states the vinyl that has been used, is actually the vinyl that has been used?
I am not doubting your word, just that someone telling you this, does not mean that it is fact.is this a complex wrap in as much as there are demanding recesses or just general vehicle curves?
quote Robert Lambie:Who has provided you with the information that states the vinyl that has been used, is actually the vinyl that has been used?
Hi rob,
The vehicle the pictures from is the rear of a Ducato so no complex curves, the company that wrapped the vehicle mainly use 3m and you can tell from the adhesive that its a 3m product.
The other vehicle where the laminate is coming away from the wrap is a sprinter so a more challenge vehicle however the laminate is coming away on the flat panels as well as the recessed areas. -
Here’s the adhesive pattern on it rob, is that a 3m glue pattern? It sure smells like a 3m product
quote David Hammond:What are you using now to remove the wrap?
I’m using image perfect vinyl remover pro now, the laminate just peeled straight off of the media so I’ve just soaked it in remover and I’m battling through it! Nightmare job, the Avery wrap I installed removed easily. I’m wondering if the previous company used the wrong laminate maybe.
I’ve never used these vinyl removers.
From what I’m reading looks like the “remover” is not penetrating well enough to get to the main vinyl.But why dont you try heat gun, wall paper remover?
Ditch the chemicals, get a wallpaper steamer on it, it’ll get the heat into the panel, far easier to remove :thumbsup:
If this is indeed one of the 3m wrap range, I have always found them quite easy to remove, never seen this happen the way you describe.
This is what cheap vinyls do. -
quote Pane Talev:I’ve never used these vinyl removers.
That’s what I started off using! We started off warming the panels as usual and started removing and the laminate started separating as per the pictures attached leaving the wrap media stuck to the van, because the wrap media is a thin vinyl it then just removes a small piece at a time before it breaks, I’m just heading back to the van now to carry on soaking it with remover which seems to be slowly working, the other identical van wrapped by ourselves and a truck we also wrapped removed effortlessly.
Bit of a strange one -
We have also found a section of wrap on another part of the same van where water has crept behind the laminate leaving a bubble of water between the laminate and print media! I’ve never seen an issue like this before! Is there a way to attach videos here?
The part of wrap where we have found this issue is staying on the van so we have been asked by the customer to try and fix the issue! -
So the laminate hasn’t adhered to the printed vinyl?
I’ve only ever seen this years ago, with dark colours printed with a 1st generation latex printer – the overlaminate didn’t seem to adhere, and could be peeled off. Never seen it since.As for removing… +1 to wallpaper steamer and lots of time 🙁 tried the chemical solutions once, didn’t work for me, made more mess than help.
quote Colin Crabb:So the laminate hasn’t adhered to the printed vinyl?
We’ve managed to remove most of it now with vinyl remover! Worked a treat when left to soak for a good while. I think it’s an issue with the print tbh, I know it’s been printed on a latex but I’m unsure what model.
Seems strange
Mark, as you say, It does look like 3M’s adhesive but it doesn’t mean it’s their "wrapping film". It could simply be a 3M cast which would explain why the film is thin and very difficult to remove. The laminate only has "ink" to adhere too, which explains why that’s coming away easier than the base film gripping strongly to the painted body surface.
This is common…
We were asked to strip 10 colour change wrapped vans that were going to be sold but asked to also wrap the 10 new ones that are replacing them.
I know the wrapping company that did the originals and they do do a lot of wraps. However, these ten vans of theirs we were to strip were done using Avery 800 Cast. These were just colour changes with cut vinyl on top but were not easy to strip and we spent much longer trying to remove the vinyl than we had quoted. Worse still, its a narrower roll of vinyl, so there were vertical joins in the middle of van panels.
There is no reason for doing this other the wrapping company saving themselves money on the vinyl as its a fraction of the cost of Avery Supreme. However, the application process is harder and slower and when it comes to removal, well, you know how difficult it can be! :rollseyes:
