Activity Feed › Forums › Sign Making Discussions › General Sign Topics › Looking for round Correx boards
Posted by Warren Beard on May 16, 2011 at 1:48 pmApparently these can’t be done on a CNC and the quantity is too low for die making.
Anybody got any idea on how to get a round shape from Correx?
Warren
Fred McLean replied 12 years, 11 months ago 5 Members · 6 Replies -
a zund type machine that has a knife that goes up and down might do it
well to be honest you should really be looking at other materials and not correx
they for estate agents boards (but not for estate agents 😕 :lol1: ) they want them to almost be disposable so need cheap as chips really, otherwise might have to look at 3mm Foamex
don’t know how it would cut with one of these, but i was looking to make some wooden signs with this technique.
http://www.youtube.com/watch?v=CpeedCL0QNg
you would only need to sandwich the correx between two wooden sheets and attach the jig to the top sheet. then re-use the wooden sheets as a template to cut more with the router.
i often use hair brained ideas like this to make stuff. Not sure if it is worth the effort, depends on how many you are making.
Liam
I presume if they cant be CNC’d then its not good making a template and routing?
They could probably be waterjet cut (they can cut almost anything) if you have enough to do. You could try calling these
http://www.tolgarengineering.co.uk/WaterJetCutting.aspx
Colin
3mm fx on a wall ok, 3mm fx fixed to a post is too floppy
Get someone to cnc a 10mm perspex or 18mm ply template depending on how much of them you’ve got to do and using a trimming router bit with a bearing zip round about them.
We’ve done quite a few shaped correx boards this way and leaves a wee bit of a furry edge, just needs a brush with a piece of sandpaper 😀
