Home Forums Vinyl Cutter Discussions Roland Cutters looking for roland engineer in hertforshire/essex area
  • looking for roland engineer in hertforshire/essex area
    Posted by Shawn Bentley on 11 April 2016 at 08:23
    hi guys I’m looking for a roland cutter engineer to pop in and help correct the print and cut alignment on my machine, theres nothing wrong with machine cuts great and perfect on normal vinyl cutting but when i print/laminate and cut on my roland xc540 printer then perform die cut and perf cut around items they are out by about 3mm, it just needs someone who is used to roland cutters (always used graphtec in past) to do set up in menus properly, keep pulling my hair out :lol1: , cheers in advance shawn
    Jonathan feeney replied 8 years, 3 months ago 4 Members · 9 Replies
  • 9 Replies
  • John Penkman
    11 April 2016 at 09:46
    Andy Broom at CMYK-Solutions maybe worth asking. If he can’t get to you he may know someone who can.
  • Shawn Bentley
    11 April 2016 at 09:57
    Thanks will give it a go cheers
  • Stafford Cox
    12 April 2016 at 14:40
    Hi Shawn. Have you been through all the print and cut adjustments in the service menu or do you think you have a mechanical problem somewhere?
    Stafford
  • Shawn Bentley
    12 April 2016 at 14:57
    Hi Stafford no Defo set up problem lol, I just don’t have the time to keep Doing prints with crop marks to test them, also when I spoke to Roland tech support it was quite confusing, is there a quicker way to get this to align with printing a test every time with crop marks? Many thanks in advance Shawn
  • Stafford Cox
    12 April 2016 at 15:15
    There are a couple of calibrations you can do in service mode. Mainly the one that prints out the graph type pattern and then cuts up and across the feed and scan axis. You then tell it where the cut line best lines up and Bob’s your Monkhouse.
    Also, have you replaced your pinch rollers lately? Particularly the outer ones.
    Stafford
  • Shawn Bentley
    12 April 2016 at 18:23
    hi stafford, sorry i need to correct my question just noticed i got it wrong, ok i am printing on my xc540 roland then die cutting on my gx500 roland, its the gx500 that is about 3mm out, the xc540 is spot on (just finished a run of 3000 die and perf cut on there and everyone spot on, the gx500 however is running about 3mm out so thats the machine that i need to correct, i bought it in to help die cut and perf cut the big order but because it was running out i never bothered, now order is out of way id like to get it sorted, cheers for help regards shawn
  • Stafford Cox
    13 April 2016 at 08:21
    Ah, OK.
    I can’t really help then unfortunately.
    Give Julian Mildner a call a call on 07500 221147, he might be able to help.
    Stafford
  • Shawn Bentley
    13 April 2016 at 14:21
    cheers stafford
  • Jonathan feeney
    9 September 2017 at 12:12
    Hi guys sorry to open up an old post does anyone know of a Roland engineer in Scotland (glasgow area )?cheers
