Home Forums Sign Making Discussions General Sign Topics Leaning roller banner issue – why is it facing forward?
  • Leaning roller banner issue – why is it facing forward?
    Posted by Nick Minnery on 18 November 2015 at 14:27
    Can anyone suggest a reason why this roller banner is leaning forward? I can’t remember where I got the cassettes from, but they certainly weren’t t cheapo ones,
    Thanks in advance for any tips
    Nick
    Simon Worrall replied 10 years, 1 month ago 8 Members · 9 Replies
  • 9 Replies
    18 November 2015 at 14:29
    I’m guessing you’ve checked the pole at the back is properly seated?
    That said, I’m sure you have.. I’ve noticed this on a number of the ones I’ve made, cheapo or posh!
    Hugh
  • Nick Minnery
    18 November 2015 at 14:34
    quote Hugh Potter:
    Hugh
    Hi Hugh
    Yes mate, I made sure the pole was sat on the little plastic bit properly. I’m thinking that that spring in the cassette is too strong. It’s weird, this is the last of a batch I bought, I just seems to be this one that I’ve struggled with! :banghead:
    18 November 2015 at 15:01
    strange indeed, if it’s only the one.
    H
  • Martin Cole
    18 November 2015 at 15:07
    Try turning the feet inwards about 30degrees. Have had same problem and I’m sure that helped.
    Obviously not the root problem but may help on this occassion
    18 November 2015 at 16:18
    Also check the pole in the rear is located correctly/fully into the hole, as if it’s not it can cause this issue.
    18 November 2015 at 16:46
    Must be the feet are slightly bent surely?
  • Stephen Morriss
    19 November 2015 at 09:39
    Too much tension of the return spring?
  • PeteMiller
    19 November 2015 at 21:51
    Is the pole damaged or too weak? But normally it is as others have said the pole in not seated fully home in the hole. Sometimes it has to be wrinkled a bit.
  • Simon Worrall
    20 November 2015 at 03:31
    I had exactly the same in one of a set of 3 that I made.
    Traced it to a dent in the top layer where the rod first goes in.
    The importer paid for the replacement.
    And I have started getting the more solid pullup base.
    They cost a bit more but its worth it.
