Leaking Light Units. what should I do?
A bit of a saga this has turned out to be and any ideas how to solve it would be appreciated.
Back in March I supplied two new swing signs for a hotel and they wanted trough lights for each sign.
Somehow I missed Portland’s direct order number and ended up purchasing the lights through a 3rd party sign trade supplier. They were advertised asquote :“We supply the aluminium trough lighting system from Portland to fit all our brackets.
They are sealed & tested to IP64, and specifically designed for this type of application”First off all the lights all arrived with broken tubes through not being packed correctly.
Then when new tubes were sent I found when taking the end caps off to change them that the end caps had no seals and in fact when I looked at the Portland website they had completely different caps. The Portland ones enclosed the whole end of the extrusion whereas the ones supplied to me did not fold around the edges but were a flat plate, How could a flat plate with no gaskets be waterproof?
I then also found that the polycarbonate lenses had no gaskets in them where they fitted in the extrusion case. I only found that these should be in place by discussing what they should really be like with Portland.
When I contacted the supplier they made me feel awkward, and that I was being picky before eventually agreeing to get the correct parts from Portland, send them to me so I could make up the lights correctly myself.
So eventually got the lights made up and I fitted them to the signs. An electrician then came and connected them to the Hotel light circuit.
There then followed 6 months of trying to get paid with constant reminders, legal threats and turning up on their doorstep.
They had pleaded cash flow problems so I had given them the terms over 4 months but when they faulted on those I managed to get the final payment by turning up at their reception. They gave me the cheque but then complained that the lights were tripping out their lighting circuit.
Seemed strange they had waited 6 months to tell me this but I immediately had a look at them and contacted the Electrician.
He confirmed that the circuit was tripping but admitted on this first conversation that it was probably not the trough lights but old wiring somewhere else in the circuit.
He also admitted the management were hard to deal with and were not paying him on time either.
I took a couple of end caps off and all looked fine , and even if moistiure did get in the lens it would be nowhere near the electrics inside. So left them while the electrician tested the circuit more.
A couple of weeks later I get another call from the electrician saying to come and take the lights away as they were full of water and still the circuit was tripping. He also claimed there was no way to check the lights and that they would have to be changed to rule them out.
When I went this time there was a small amout of water in one lens and condensation in the 3 other lights. When compared to some other Portland lights on the next door hotel which had no sign of water ingress I could not say that the ones I had supplied were totally waterproof.
Both Hotel Owner and Electrician had seen water in the lens and demanded they be changed. I could only agree that there was water in them and duly removed them.The supplier did not want them back and only after a long discussion did they agree to have a look at them.
They have now been back at the supplier for over two weeks and despite several phone calls and emails only managed to speak with the owner yesterday.
He is now claiming that he has stood the lights outside for a week and there is no sign of water ingress and they do not trip a circuit on his test bench, so does not want to replace them but send them back to me.So, Where do I stand?
There is no doubt they were not supplied correctly to me in the first place.
There is no doubt that water did get into the lens while they were in place on the signs.
It is questionable if it is faulty lights or faulty wiring which is tripping the Hotel circuit.
The electrician obviously wants them changed to make his life easier and the Hotel owners obviously want them changed as they have seen water in the originals.
I would like my money back and buy the proper complete units direct from Portland.
I seem a bit stuck in the middle here and not sure what to do.
Sorry for the long post but it seems to turning into a bit of a nightmare on several fronts this one.
