Home Forums Software Discussions Adobe Software Layering Fonts
  • Layering Fonts
    Posted by simon j denver on 30 March 2014 at 20:24
    Hi all
    Six months on and still a novice on adobe illustrator
    Im after layering some fonts to give them a ”border” i can add strokes to lettering which gives the effect i want just cant seem to get it to cut the same when sending it to summa cut
    any help is very appreciated
    thanks Simon
    Martin Grimmer replied 11 years, 9 months ago 4 Members · 5 Replies
    30 March 2014 at 20:37
    Don’t use illustrator Simon but can’t you add an outline, that’s what you really need to do if your cutting vinyl rather than printing. Far as I know the stroke is just the thickness of the line which as I say would work if printing.
  • Paul Atherton
    30 March 2014 at 21:21
    Hiya
    In illustrator select your font with the desired stroke then go to object then path then outline stroke
    You may need to convert the text to outlines first (so they are shapes nd youcant edit what it says)
    Sorry hard to say when I’m on phone easier to explain when on the PC
    Hopefully that shud be what ur after
  • Paul Atherton
    30 March 2014 at 21:24
    Don’t worry I’m 6 years on and still a novice I found it a bit like trying to understand women 😉 or for the lady posters understanding guys
  • Tony Bird
    30 March 2014 at 23:13
    Once you have added the stroke you need to create outlines then you need to go to path (I think) & create outline stroke, then go to your pathfinder and click merge. That will be done, if it won’t merge make sure the stroke colour is the same as the main colour.
  • Martin Grimmer
    31 March 2014 at 08:50
    Hi Simon,
    You could also try following:
    Select text and convert to outlines (make sure you have a backup of original in case you need to change text in future). Won’t work if you don’t convert to outlines.
    Then object>path>offset path. Various options for square or rounded edges, size of out line etc. Ungroup if you need to.
    Martin
