Home Forums Sign Making Discussions General Sign Topics Larger sized aluminium composite boards/panels
  • Larger sized aluminium composite boards/panels
    Posted by Peter Johnson on 20 August 2018 at 18:32
    Hi all.
    Was just wondering if anyone knows of any suppliers of aluminium composite boards/panels larger than 4080mm in length?
    Thanks in advance,
    Pete J.
    Robert Lambie replied 7 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Andrew O Brien
    20 August 2018 at 19:17
    3A composites as in the real diabond do 6m lengths
    20 August 2018 at 22:37
    we have been using a lot of 4m x 2m sheets of composite, thats hard enough to handle.
    Why would you require such large sections in one piece?
    Have you considered how you intend transporting the sheets this size and handling to install?
  • Peter Johnson
    20 August 2018 at 23:41
    Hi Andrew, thanks for that.
    Hi Rob. Somebody wanted me to quote for a job that required a sign at just a little over 9m wide, but they only wanted the sign in 2 parts.
    I have worked with 3m boards and yes, that was a little awkward on my own, but manageable. But 5m? No way. I just wanted to know if there was a UK supplier available just in case, for whatever reason, I might need something like this. Point of fact, I was asked a few weeks ago if I could possibly fabricate a 4m tall x 6m wide full colour backdrop for a video filming background, but as it sounded like a vague request, I didn’t pursue it and didn’t know where to source larger substrate.
    As I was asked a second time for something larger than standard, I thought I’d actually see if I could find a supplier.
    But I totally get your point. My van could never cope with transporting something that size. But if the customer was willing to pay, I’m sure I could figure something out.
    23 August 2018 at 00:47
    When working with or being asked to quote for work in a large format "single sheet" or "no joins" finish, you should really consider a tensioning frame. I have done a fair bit with these over the years… both tension frames and flexi-face systems.Does Not have to be a full blown flexi-face system.
    you can get tension systems that will take banner and you simple chap/hammer a bead into place and it pulls flat large single piece banners.
    the following is good for tension frame. you simple screw to the surface, overlay the banner and chap in the face clip with a hammer.
  • Colin Bland
    23 August 2018 at 06:05
    Who supplies the system in the first picture Rob?
  • Andrew O Brien
    23 August 2018 at 07:05
    quote Colin Bland:
    Spirit displays
  • Colin Bland
    23 August 2018 at 09:58
    Thanks Andrew
    27 August 2018 at 17:01
    Sorry for the slow reply Colin….
    Yes Spirit displays does them and a few other similar extrusions doing similar jobs.
