What would be the easiest way to attach a small dibond rectangular "Private Parking" sign to a lampost. Would it be some form of screw banding and would it be easy for the customer to fit themself.
Hi russ i have used cable ties on small no parking signs etc on lamposts with no problems i use them with hard plastic cable tie mounts you can get self adhesive ones but i normally pop rivet them on
will post a picture in members file store
Easyest would be heavy duty cable ties, cheap as chips from srew-fix but available everywhere. Just cut 2 slots or holes in the centre, top and botom about 40mm apart,
You can also buy jubilee type clips to cut to any length, from auto shops.
If its on a public lampost, it will get removed quickly anyway….
reason i said it was because i was fitting similar to palaside fencing last week and one also onto a road sign post, all temp stuff but was pretty solid with just a couple of screws.
Please note:
