Home Forums Printing Discussions General Printing Topics Laminator : Seal 62 plus problem, help?
  • Laminator : Seal 62 plus problem, help?
    Posted by Jamie Laird on 19 January 2013 at 05:45
    Hi all
    The top roller on our seal 62 plus laminator wont lower. It’s electronically controlled rather than mechanical.
    Checked all normal reasons…emergency stops both up, tray lowered into position, nothing tripping photoelectric eye/laser…that’s what looks most likely but there’s nothing there.
    We notice only the right hand side has a red light, the left side just a small hole, can’t remember if this is a receiver or it too should send out a red beam?
    Are there any related fuses, micro switches or a way to trick it? Important deadline on Monday and we’re stuck without it.
    Any help much appreciated, thank you.
    Chris Sullivan replied 10 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Jamie Laird
    19 January 2013 at 06:01
    Sorry, didn’t mean to upload 3 images of same machine…didn’t look like it worked first and second time.
    19 January 2013 at 07:27
    have a similar laminator, and when that happens there is a fuse blown, they are located behind the panel at the right hand side, i dont change them so cant help further 😀
  • Jamie Laird
    19 January 2013 at 08:57
    Hi Nik
    Thanks for the tip…we’ll check it out…much appreciated, have a great weekend! X
  • Denise Goodfellow
    19 January 2013 at 14:00
    We have a very cheap laminator, very small fuses we get them from marlins, if the fuse keeps blowing, something’s wrong…
  • Jamie Laird
    21 January 2013 at 08:57
    unfortunately it wasn’t the fuses 🙁 thanks for the tip, I wish it had been.
    Does anyone know of a Scottish based or even UK based Seal technical support guys? I know of A-tech…are they the only ones?
    Jamie
  • Andrew Blackett
    21 January 2013 at 22:43
    Theres Simon at Laaco laminates, http://laacolaminates.co.uk/repairs.html He’s based in Stockport
    Looks after our Seal machine and really knows his stuff, hopefully might be something he can advise over the phone for you.
    Andy
  • Chris Sullivan
    15 September 2015 at 10:57
    did you manage to find a solution, as my Seal has the same problem, when trying to mount on 10mm pvc
