Home Forums Printing Discussions General Printing Topics Lamination- hot or cold?
  • Lamination- hot or cold?
    Posted by chorley signs on 30 May 2005 at 19:21
    Hi all,
    I’m new to the wide-format inkjet scene (having used a PC60 for 2 years). I can use our VersaCamm SP300 quite well and have produced a few samples and even quite a large sign (for indoors). However although we are quite pleased with the durability of the ink up to a point, we do know that many things will need laminating. I have seen all kinds of laminators advertised- what do I need to go for considering we will want full width (700mm), should it be hot or cold? we are printing onto vinyl
    Thanks in advance
    Rob
    Kevin Flowers replied 20 years, 7 months ago 5 Members · 5 Replies
    30 May 2005 at 19:24
    On vinyl you can only cold lam as far as a I am aware, hot lam is for paper prints
    lynn
  • chorley signs
    30 May 2005 at 19:44
    thanks Lynn, anyone got any recommendations on cold laminators (or even ones to avoid!) we won’t be using it loads so it doesn’t need to be anything fancy really
    Rob 😀
  • Russell Huffer
    30 May 2005 at 19:52
    You do only need cold but if you find a laminator that does both, so much the better. I have a Hot / Cold with variable temp control, I have only ever used it cold execpt for one job in two years, altough I always put a small amount of heat into rollers 25 – 40 C just to soften film.
    I would say more important is to go for the widest you can afford as you may only have a 700 m/m job now but you do not know what is round the corner.
    Russell.
  • Rod Gray
    31 May 2005 at 11:52
    Rob,
    Don`t buy solely on price and make sure you get either an on-site demo, or go and see one of the laminators, you have shortlisted, in action.
  • Kevin Flowers
    31 May 2005 at 17:01
    Hi al
    i brought a Xativa when i brought my Rocky 38, speak with Harry at Edward Mathius link on home page of this site. I had never used a laminator b4 i think i have only sodded up one print in all the time i’ve been using it, easy bit of kit to use for laminating and mounting.
