Home Forums Sign Making Discussions Vinyl Label Material needed
  • Label Material needed
    Posted by Daniel Evans on 10 December 2015 at 11:37
    Hey guys
    Just been asked to produce some labels, they’re for putting onto information rather than stapling business cards to.
    What’s the best/cheapest material for this, price is an issue?
    Chris Windebank replied 9 years, 11 months ago 7 Members · 11 Replies
  • 11 Replies
    10 December 2015 at 12:51
    Depending on the size and quantity we sometimes run them on pre-cut sheets through our small format digital machine, they’re available in a wide choice of sizes, and finishes.
    If bigger we run them on the large format machine but on vinyl, Metamark’s MDP is 100micron so good for labels
  • Daniel Evans
    10 December 2015 at 13:17
    Thanks David
    The metalmark material is what I was going to go for, just wondered if there was anything else out there that was cheaper.
    Clients a bit of a tight git
  • Michael Kalisperas
    10 December 2015 at 14:01
    We use 100micron 5 year stuff it’s lovely stuff and comes in 750 wide. Costs us about £40 for 50m role from memory had brought a load for a job. Still have some roles. It’s solvent based with clear adhesive. Where are you based can send you sample of you like to test. Alternatively md5 100 is also good. The stuff I use is from Italy but can’t source it anymore ;(
  • Daniel Evans
    10 December 2015 at 14:05
    Hi Michael
    Thanks for the offer but this will be an ongoing thing so I need to know that I can source the same stuff again and again, they are quite particular but that is the kind of price i like lol.
    10 December 2015 at 14:12
    quote Daniel Evans:
    Hi Michael
    I would go with md3 100 then
  • Lorraine Clinch
    10 December 2015 at 14:19
    Depends on how large the labels are, I have great success with MD3 for all types of label. One customer puts them on the lids of her home-made preserves, and the labels wash time after time, and never fade either (Lightbar).
    Why is it that paper for labels is more expensive than vinyl? It beats me!
    Lorraine
    10 December 2015 at 14:21
    quote Lorraine Clinch:
    Lorraine
    Lorraine I have wondered the very same but my mind got so confused like trying to work out how space carries on so I gave up thinking and just pay it 😉
  • Jamie Wood
    10 December 2015 at 15:48
    Antalis gave us a very good price on Orajet 3164 gloss white perm, so may be worth ringing them.
  • Daniel Evans
    10 December 2015 at 15:56
    Thanks Jamie
    I’ll give them a call.
  • Wayne Fothergill
    10 December 2015 at 17:32
    We use a lot of Hexis V3000 for simple labels and contour cut stickers. Has great stability at 100 micron and at £45 for a 760mm x 45m roll it’s quite cheap.
  • Chris Windebank
    11 December 2015 at 18:08
    grafityp do a self adhesive mat poster paper I have used for cheap labels (to seal florists wraps) no weeding either failing that the metalmark low energy vinyl that’s sticks like s**t is thick and works well
