Activity Feed › Forums › Sign Making Discussions › Off Topic Chat › keyring making machine.
Posted by Matt Boyd on March 20, 2006 at 11:16 pmdoes anyone know where i can buy a keyring making machine? the rubber keyring type not the metal keyring type. i have looked on the net and asked about but haven’t come up with anything!
thanks allMatt Boyd replied 18 years, 1 month ago 2 Members · 10 Replies -
matt, Why do you want to make them? are you going to just supply or add value? IE put a clients name on them as in a free/promotional item?
Stuff like this can be bought very cheap, simply because they are produced in the thousands by specialist manufacturers.Peter
Hi peter, i buy them in from a company now but only buy certain keyrings i.e motor sport related ones and thought it maybe easier and cheaper in the long run to buy a machine myself. i have no idea what money is involved though. also means i can do other keyrings and offer a wider service
the actuall rubber fob not the chain or metel ring, although i’d need those also.
Either way matt, I would buy them in, you would need to make thousands to justify a machine,.
Matt, you need to do a bit of research, or at least specify what you need to produce, and how many per hour/day/week.
flat die cut, 3d colours? 1 2? complex or simple design?
cheapest machine to die cut flat rubber is relatively cheap, but slow.
so how long is a bit of string?Peter
yeah see what your saying peter! i friend of mine has seen a company that do a machine in wales, something do to with roland i think?!?!? he doesn’t know much about it though! just woundered if anyone had one or new of where i can get some info. jusy totally going off the topic do you now what day you guys and gals are meeting at sign uk, i read the post(can’t find it now) which rob posted and i know it was 1 o’clock at the europoint stand yeah? just need to know the date so i can look into booking my flight etc
cheers for that peter, i couldn’t remember!!!!!! i’ll probably fly over for 3-4 days then head back. i’m actually from north wales, thats where i’ll be staying so it should only take 2-2.5 hrs on the wednesday all going well.
