Home Forums Sign Making Discussions General Sign Topics Job Setup Advice
  • Job Setup Advice
    Posted by Greg McCarthy on 13 June 2014 at 12:00
    Hello all,
    I hope you can help me. Im spending way too much time manually cutting some vinyl for a customer who wants full rolls of vinyl cut at 300mm intervals.
    I need to be able to put the vinyl into our printer (print/cut) and then for it to sheet off at 300mm intervals until the roll is finished. Sounds easy. Can I figure this out?? No..
    When I try to sheet off its giving us extra material which we dont want.
    If anyone can suggest a simple way and efficient way of doing this we’d be very grateful.
    Greg
    John Thomson replied 11 years, 6 months ago 2 Members · 2 Replies
    13 June 2014 at 12:20
    One of our old suppliers had a device on a bench.
    2 rollers the vinyl sat on, and a smalle wheel/counter device. Pull the vinyl out the counter measured it, run a blade across the bar.
    Our graphtec allows for perf cutting, but not sure that would be able to do what you ask?
  • John Thomson
    13 June 2014 at 13:55
    If it was me I would cut a piece of dibond to size then place it on the vinyl and run a blade down it.
