Home Forums Printing Discussions General Printing Topics Jetster Nozzle Cleaning
  • Jetster Nozzle Cleaning
    Posted by Fred McLean on 28 May 2007 at 10:32
    Any tips?Have spent the morning trying to get the black to work and
    now the others are disappearing!Can i take out all the carts and plug in the original cleaning fluid ones to flush the system or just keep on going?
    Have cleaned capping station etc.
    F
    Fred McLean replied 18 years, 7 months ago 2 Members · 4 Replies
  • Kevin Flowers
    29 May 2007 at 16:32
    Fred
    just a quick reply for now,
    1. remove the right hand end cover
    2. separate the tubes running down to the waste bottle (one at the time)
    3. fit syringe to pipe lift cover & gently push head over onto capping station, whilst gently pulling on the syringe until syringe begins to fill (you should feel resistance just keep a constant pressure & don’t just pull the syringe to its max)
    4. repeat for next tube.
    ensure machine is switched off, when you switch on machine may do a clean then try a test print. You may have to repeat
    Hope this helps, let us know how you get on.
  • Fred McLean
    30 May 2007 at 07:14
    It gets worse!!!
    Spied a tube had come out of the pump unit!!!
    It’s under warranty 😀
  • Kevin Flowers
    30 May 2007 at 07:53
    Fred
    call them in, its not worth touching it yourself. Make sure you watch the tech its worth while getting to know your machine. Pump change is relatively easy job. Make sure you have plenty of Tea &Biscuits its always good to get chatty with your techs you never know when you’ll want help over the phone or when the machine is out of warranty.
  • Fred McLean
    30 May 2007 at 08:59
    Allways do Kev,i’ve an engineering kind of background so once things are out of warranty you can get in about with nice precision instuments(hammers etc.) 😉
    Tech coming this morning 😀
