Home Forums Printing Discussions HP Printers Issues printing onto Contravision Performance with HP365
  • Issues printing onto Contravision Performance with HP365
    Posted by Myles Brewer on 20 April 2021 at 11:25
    Hi All,
    Just wondering if anyone has had issues printing onto Contravision with the HP365?
    I’m sure I’ve managed previously to do a few bits but I’m having major issues currently with the media lifting slightly right in the centre & the head then just ribs it & smears the ink before it leaves the platten & feeds into the dryer. I’m using a generic SAV profile (There doesn’t appear to be one for Contravision) & have tried ramping up the vacuum to about 65 but no luck & it ain’t cheap stuff to keep testing!!😢
    Myles Brewer replied 4 years, 7 months ago 3 Members · 6 Replies
  • Colin Crabb
    20 April 2021 at 16:05
    Is the media connected to the take up system ?
  • Russell Huffer
    20 April 2021 at 21:40
    I am seeing exactly the same issue on my JV33 the way i cure it is by lifting the head up to max height.
  • Myles Brewer
    21 April 2021 at 11:00
    Hi Colin, No it isn’t & from previous similar experience with certain papers even that doesn’t seem to cure the issue. I didn’t want to go that route due to waste & it being an expensive media, but can try adding a bit of cheapo monomeric as a leader I guess.
    Russel, Unfortunately, you can adjust the head height on the 365 as far as I’m aware.
  • Colin Crabb
    21 April 2021 at 16:33
    Make sure media is exiting the machine by 6inches, add some weights (we use heavy duty bulldog clip and small lump of brass from and old machine 🤣)
    This will keep the media in tension while going through the heater section, helping reduce the media ripples.
    Heat may need to be reduced from generic profile,
  • Myles Brewer
    21 April 2021 at 17:57
    Thanks Colin, will give that a shot, fingers crossed.🤞
    Will let you know how I get on when I get back to it.
    • Myles Brewer
      22 April 2021 at 11:04
      You’re a genius Colin!!👏 That seems to have done the trick along with a different profile with 16 pass & 70 vacuum.👍. Just the job & thanks for the help.
