Home Forums Sign Making Discussions Vinyl is there a vinyl suitable for an outside canopy?
  • is there a vinyl suitable for an outside canopy?
    Posted by Tim Hobbs on 24 August 2007 at 12:52
    Hi Guys
    Does anyone know if there exists a vinyl that would be suitable for a canopy outside of a shop that is rolled up every day?
    I.E. one that is VERY flexible.
    I don’t think banner vinyl would be up for it and I don’t really want to signwrite the logo by hand. Although it might be nice to get back to my roots for a change!
    Tim
    Brian Little replied 18 years, 3 months ago 8 Members · 14 Replies
  • 14 Replies
    24 August 2007 at 12:57
    if its a canvas canopy ide say definitely not mate…
    brushes would be best i think…
  • Tim Hobbs
    24 August 2007 at 13:01
    Yeah, you’re probably right Rob.
    Bring out the One Shot Soft-side!
  • Tim Hobbs
    24 August 2007 at 13:03
    What about canopies made from vinyl though Rob?
    24 August 2007 at 13:04
    i recon a cast would do the trick mate but i think it depends just how squashed it gets when closed. ide imagine it would be fine though.
    worst comes to worst on the vinyl canopy you could create a vinyl stencil and paint it in then remove stencil.
  • Ian Bingham
    24 August 2007 at 13:06
    Hexis have come out with a new hi bond vinyl, this may be better
    Ian
    24 August 2007 at 13:09
    hi-bond for vinyl canopy or canvas ian?
  • Tim Hobbs
    24 August 2007 at 13:13
    Thanks Ian
    I guess we could always contact them for a Fact Sheet on the product.
    No harm no foul.
    Tim
  • Ian Bingham
    24 August 2007 at 13:14
    its a hi bond vinyl for sticking to the likes of motor cycles and wheelie bins, not the usuall thick stuff, going to order a sample from them next week
  • Steve Morgan
    24 August 2007 at 13:27
    The only roller blind/canopies I’ve come across were made from the same material as curtain sides for lorries and consequently the same problems. Best bet vinyl screen inks and a brush
  • Nigel Pugh
    24 August 2007 at 13:31
    Ask John Harding, I know he used textile vinyl on a canopy without any problems, I cannot recall what the canopy was made of though.
  • Craig Brown
    24 August 2007 at 16:21
    If you don’t feel comfortable signwriting the blind or using a vinyl stencil with ink, the APA truck vinyl should be a viable alternative – have done a lot of PVC Canopies over the years with no come backs at all.
    24 August 2007 at 16:33
    Yip… i agree craig, i never thought of truck vinyl… that would do the job no problems.
  • John Harding
    24 August 2007 at 17:09
    I did a job similar to this – the problem was the canopy was stitched to the frame so although I could remove the frame I couldnt take it away in my van hence I used heat press material from graphityp and just ironed on on site.
    Client understood this was not guaranteed as the material normally goes on with a heat press so she was happy to sign my disclaimer 😀
    Turned out ok although very slight lifting the edges where I didnt get the heat spot on – practice makes perfect!
    If truck vinyl works it might be better from the rolling up aspect
    will post a pic elsewhere
    here unless moved
    http://www.uksignboards.com/viewtopic.p … 313#230313
  • Brian Little
    24 August 2007 at 19:27
    for durability i dont think you could go wrong with the one shot soft side …or sericol screen ink…which drys a bit quick but years ago in the late seventies i seem to remmember my boss using siricol on the first curtain siders
