Home Forums Sign Making Discussions Vinyl is R-Tape the best application available?
  • is R-Tape the best application available?
    Posted by Bart Van Wassenhove on 12 January 2006 at 10:36
    Goodmorning evrybody,
    i’ve been using Oracal application for five years now. Most of the time it worked out well. The only problem was the curling up of the edges.
    Thanks to some advice on the boards i decided to try R-Tape application paper. To be honest i didn’t believe it would make a lot of difference :lol1:
    Once again this place proves it quality! R-tape stays as flat as it can, no wrinkles, no curling!!! The difference is huge. No dirt or dust can come between the application and the backing paper. R-Tape totally fullfills the expectations :dance4: :dance4:
    Thanks again to the boards-advice :praise2: :praise2: :praise2:
    Ramj replied 19 years, 10 months ago 14 Members · 25 Replies
  • 25 Replies
    12 January 2006 at 11:08
    is R-tape a brand name ? i’m just about to buy a couple of new logs so might give it a try,
    cheers.Hugh
    12 January 2006 at 12:28
    Been using R Tape for a few years now, really is the best stuff.
    I am very loyal to the Oracal brand normally, but have had a whinge a few times to my distributors here in Oz. Our humidity is so high, after a day the oracal just falls off or loses its tack.
    Poly tape is worse tho.
  • steve geary
    12 January 2006 at 13:49
    iv’e tried at least 4 brands, and stuck with R tape for the last few years. works the best for me too.
  • Mark Shipley
    12 January 2006 at 17:47
    I agree ‘R’ Tape is the best. I’ve used it for well over 18 months now and personally I couldn’t go back to using standard app. tape!
    RLA 4075 is the stuff 😉 @ http://www.rtape.com
    Mark
  • Lee Ballard
    13 January 2006 at 04:49
    Yup I only use r-tape. Guess I was lucky, was suggested by my first vinyl supplier and I’m so happy with it I haven’t even thought about trying anything else 😀
  • George Zerbino
    13 January 2006 at 08:05
    Same here, been using R-Tape Conform for the past few years and have no intention of switching to anything else – have used various different brands in the past and always had problems.
    Only negative comment about R-Tape is the fact that when you are at the end of the roll (last 10-15%), it is wound up pretty tight and can be pretty hard to unroll it, specially when using the wider rolls.
  • Dave Bruce
    13 January 2006 at 08:38
    I am looking for a new supplier of R tape as Andersons have stopped supplying it, any suggestions please.
    Dave.com.com.com
  • Mark Shipley
    13 January 2006 at 08:51
    Dave,
    Hexis sell ‘R’ Tape
    Mark
  • Lee Ballard
    13 January 2006 at 16:39
    Dave,
    As Mark says Hexis do it, as do Metamark. Not sure of others off hand.
    Lee
    13 January 2006 at 16:42
    or cherwells
  • John Simpson
    13 January 2006 at 18:21
    won’t use anything else …………Vinyl Corp as well
    L J
  • autosign
    13 January 2006 at 22:02
    I disagree, it lays flat but I found it caused lots of static that lifted the vinyl of the bench and combined with it’s glue which doesn’t seem to be pressure sensitive I just had lots of badly masked or ruined stuff.
  • John Simpson
    13 January 2006 at 22:22
    would like to get one thing straight in my mind before going on with this subject, is “Conform” made by “R Tape”?………… because it’s conform i swear by & I think it’s made by R Tape.
    Have had to send back 2 full logs of Oracle before now as lettering virtually fell off the tape, very annoying.
    L J
    13 January 2006 at 22:27
    Thats what it says on the box john
  • John Simpson
    13 January 2006 at 22:44
    Thanks Peter, (I don’t keep it at home so couldn’t check myself)
    Autosign
    Not disagreeing with you but i think you will find that yours was or is part of a bad batch, don’t let it put you off conform.
    my previous post says that i sent back 2 full logs of Oracle, correction….I bought 4 logs on the strength of other peoples opinion on uksb, people swearing by it etc, turned out a big mistake as like you said caused a great deal of problems. Because of this i won’t use it anymore, maybe a shame for Oracle as it might have been a bad batch.
  • Nick Minall
    13 January 2006 at 22:57
    quote John Simpson:
    I was just going to order some from Oracle 😕
    13 January 2006 at 22:59
    I do like the R tape conform stuff because it stays down and doesn’t curl at the edges, but we also noticed static, graghic sort jumped at it , but we also just changed work top to glass so didn’t know who or what was the cause 🙄 🙄
    quote Nick Minall:
    still go ahead and do so nick….i like it and have tried them all….. 😀
    you must have got a bad batch john 😕
  • John Simpson
    13 January 2006 at 23:09
    quite agree Nik, but have you tried conform?
    Nick, don’t let me put you off, each to their own!
    L J
    13 January 2006 at 23:11
    we also tried oracle, dont get on with it, perhaps it came from the same batch?
  • John Simpson
    13 January 2006 at 23:20
    It’s a shame though Peter as the 751 cast is a brilliant product, even their rep agrees that the app tape isn’t up to much.
    L J
    13 January 2006 at 23:27
    never seen or spoken to a rep we order through the London office all the people are ok a rep. would be good as I had to tell them they sell felt squggies? (not up to spelling just now) and the deliveries are on time but seem waste full ordered vinyl and correx (try to order asmuch as poss in one go) delivered by differant vans all vinyl on one 20 correx sheets 813x 610 differant van why 🙄
    13 January 2006 at 23:29
    I found oracle app tape somehow not sticky enough, I had to spend extra time and care when removing the backing, the graphics were staying behind, especially smaller serif stuff, at one point I thought that it may have been the vinyl that was the problem, but as they were both oracle, they should have been compatable.
    I still have a couple of rolls on the shelf, so I will only use it on large stuff
    peter
  • John Simpson
    13 January 2006 at 23:40
    I actually insisted that the rep came here to visit, best thing i ever did as he left samples of materials i didn’t know existed, such as “silhouette” which is a 5 mm matte foamboard white on one side & black on the other, 8’x4′ £12 each, cheaper in bulk. It is designed for mounting prints onto. mainly exhibition work.
    Ring them & ask him to call Lynn.
    L J
    PS you even get a bright yellow plastic briefcase to put all the samples into.
  • Ramj
    14 January 2006 at 00:33
    I agree, R-type is the best, with it’s retro side-scrolling shoot-em-up action, 😛
