Installing optically clear window vinyl – tips
Hi Guys,
I don’t install much optically clear vinyl, a couple of pointers would be great.
Regarding the water solution, I use a yello tools application fluid mixed with the water ( a bit like window cleaner to be honest) for fitting frosted film. Is this alright to use or any other recommendation?
With installing, I’v used a blue max squeegee and this seems to work, but I’m a bit unsure whether this will mark and scratch the ink. I don’t want to use app tape as I don’t want to go back and remove. I also don’t want to overlaminate as it will cost a bomb.
When printing, do you print a double pass to give better contrast to the image?
Any other tips would be great so I can be loaded with knowledge
Cheers!
