Home Forums Sign Making Discussions Off Topic Chat Installing office wallpaper print- adhesive advice please?
  • Installing office wallpaper print- adhesive advice please?
    Posted by Jon Stringer on 10 March 2020 at 08:34
    Hi All
    I’ve been asked to quote on a job to cover an office wall and I wanted to go for a one piece ‘rafa’ canvas type print rather than wallpaper strips. What’s the best paste adhesive to use for this? I’ve heard of a brand called ‘red top’?
    Jon
    Iain Pearson replied 5 years, 9 months ago 7 Members · 17 Replies
  • 17 Replies
    10 March 2020 at 19:34
    I could be wrong, but I think Spandex do a sort of canvas finish adhesive-backed material for wall prints. I may even have a sample roll of it at work.
    http://www.spandex.co.uk
  • Iain Pearson
    10 March 2020 at 20:41
    Sadly for me, Rafa canvas is a simple, quick method to cover a wall, but for installers that don’t posses the skills to hang proper wallpapers.
    Don’t use it, never will use it. Far better products to cover a wall :thumbsup:
    11 March 2020 at 11:22
    Any reason you don’t want to do it in drops?
    Here’s some we installed yesterday 5 drops, 5mm overlaps. Using a self adhesive media from Signmaster Systems, not sure what it is.
  • Derek Heron
    11 March 2020 at 12:07
    why not a one piece fabric
  • Kevin Mahoney
    11 March 2020 at 12:45
    Never used any of these wall coverings, I must look into it some more. I generally just use a matt laminated polymeric with a horizontal join
    11 March 2020 at 19:39
    Kevin,
    Any reason you do horizontal joints?
    Derek,
    How are you fixing the fabric to the wall?
  • Kevin Mahoney
    11 March 2020 at 20:10
    quote David Hammond:
    I find it much easier to join the prints on the bench in the workshop & the one-piece install is lightning fast, seems easier to me rather than multiple pieces to line up. Also, the top piece overlapping the bottom piece below eye level seems almost invisible in my opinion.
  • Iain Pearson
    12 March 2020 at 05:19
    quote Kevin Mahoney:
    so what if your walls are 4.2mts H x 11.5mts W – do you still join it on the bench and fit one piece ?
  • Iain Pearson
    12 March 2020 at 05:31
    Or what about something like this ?
  • Kevin Mahoney
    12 March 2020 at 06:58
    quote Iain Pearson:
    No, I haven’t done one that size yet.
    All the ones I’ve done have been perfectly doable in one piece so made sense to do it that way
  • Martyn
    12 March 2020 at 09:38
    quote Iain Pearson:
    The main issue is see with horizontal is that its not a 1 man install. Where vertical drops are.
  • Iain Pearson
    Have you never used wall coverings Kevin ?
    Pretty much 90% of our projects are commercial interiors, so our team are very experienced in most
    variables out there regarding materials. Some find it easier to fit one piece jobs due to time/cost restraints, others for ease of install, but in fairness, if you have good installers, then walls fitted in panels/drops are just as effective, as sometimes its more about using the correct material for the project, and each material we use or recommend has its own merits.
  • Kevin Mahoney
    12 March 2020 at 09:41
    Only ever used polymeric vinyl I’m afraid, never tried any purpose designed wall coverings. I’ll try & push it a bit
  • Iain Pearson
    12 March 2020 at 09:54
    If you ever need any help Kevin, id be more than happy to pop over with samples etc and give you some guidance
    In return to can show me some of your amazing vehicle work :thumbsup:
  • Kevin Mahoney
    12 March 2020 at 09:59
    Deal
  • Jon Stringer
    12 March 2020 at 10:33
    Thanks for the advice, although I think it went off subject a bit.
    The clients looking for a no-join finish and has asked for a one peice print. I’ve only ever installed S/A wallpaper rolls which does give an acceptable finish. Perhaps Digimura or similar is the way to go, without the overlaps.
    Thanks Jon
  • Iain Pearson
    12 March 2020 at 12:48
    Sorry Jon, as i said earlier, we would never use the one-piece stuff so ill leave it for someone that does to advise you best
    Good luck :thumbsup:
