Home Forums Printing Discussions Printer Ink Ink smudging on vinyl, advice needed?
  • Ink smudging on vinyl, advice needed?
    Posted by Lloyd Morgan on 13 June 2012 at 15:33
    I’m running some prints on the sp 300v and sometimes it seems as if the vinyl is warping in the middle and i end up with a smudge patch in the middle of a print from the head i assume touching the vinyl.
    i’ve reduced the heater to 35 and tried it off in case it was getting too hot.
    should i increase the heat to keep the vinyl flat?
    any advice thanks?
    many thanks
    Denise Goodfellow replied 13 years, 3 months ago 8 Members · 8 Replies
  • 8 Replies
  • Jamie Wood
    13 June 2012 at 16:03
    We find that increasing the temperature causes more cockling, so you are doing the
    right thing by reducing it. What brand of vinyl are you using? Some brands seem more
    susceptible to cockling than others.
  • Lloyd Morgan
    13 June 2012 at 18:28
    i use LG can’t remember the exact model number, 31** i think.
    just asked my supplier to send me a sample of slightly thicker vinyl to see if its better.
  • Nigel Pugh
    13 June 2012 at 19:39
    One thing to consider is if the vinyl itself is up to temperature before using or has it just come off the delivery van.
    Nigel
    13 June 2012 at 19:43
    does this machine have a pre-heater?
    13 June 2012 at 22:20
    from my experience lg is the worst for this if there is any dampness in the air.
  • Lorraine Clinch
    14 June 2012 at 11:34
    Also, I find that if the vinyl runs up tight to the roll this happens, also pulls the vinyl off-square. Make sure you have vinyl run loose off the roll.
    Lorraine
  • Chris Hansen
    15 June 2012 at 04:47
    Try moving your pinch rollers further into the media if you can, it may help.
  • Denise Goodfellow
    17 June 2012 at 05:30
    Do you have a take up roller fitted? if so, use that, we find it helps to pull the vinyl through better.
    I`d also try another make of vinyl, we use Oracal
