Ink levels
A useful tip for anyone with a Cadet or Versacamm (the same may also apply to other printers)
As most people know – the machines ink level indicators are re-set every time a cartridge is removed and re-inserted. Thus a half empty cartridge will register as full again (if removed to ascertain it’s weight to determine how much ink is left).
However – it is useful to know that If you remove a cartridge while the machine is switched off from the mains you can then re-insert it without re-setting the ink level recorded by the machine.
Hence – if you want to gauge how much ink is left in each cartridge without re-setting the ink level counter, do this first thing before you switch the machine on every morning.
