Home Forums Software Discussions General Software Topics importing eps files
  • importing eps files
    Posted by Tecnicasigns on 20 June 2005 at 16:58
    i’m working on a couple of jobs at the minute where i have needed to import company logos (downloaded from the web). they came in .eps format. the problem is when i import them into my sign software ( gerber advantage) it wont cut them. i can edit them & when i select output they appear in the the cut window. i hit cut and the plotter starts but only cuts the weed border (?) i have also imported them to corel then exported as .ai file but the same thing happens any ideas ?
    thx
    David Rowland replied 20 years, 6 months ago 10 Members · 14 Replies
  • 14 Replies
    20 June 2005 at 17:33
    Could you post an example in the file swapping forum? This way some members here would be able to open it and throw some light on the problem 😀
  • Tecnicasigns
    20 June 2005 at 18:34
    sorry i dont have access to file swapping 😳
    but heres a link to one of the files i downloaded.
    http://www.brandsoftheworld.com/search/ … ext=rotary
    thx for the reply
  • Keith Nilsen
    20 June 2005 at 18:44
    I generally open the files from that site in Illustrator and get rid of unnecessary data that is usually there, such as the clear frame panel that is always evident. From that point I start work in other programs. Try that as an alternative route, I am sure it will work….
  • Tecnicasigns
    21 June 2005 at 08:08
    thats what i’m doing with corel.then importing to composer. anyone else have an idea ?
  • Jayne Marsh
    21 June 2005 at 08:13
    Check to see if the file that you are importing doesnt have print only attributes assigned to the vectors. The line sshould appear as black only, if they are red or green that means that the vectors have a print fill assigned to them. set the vectors to cut only and that should clear up the problem. Its been a while since I worked with advantage, but this problem arises in newer versions of the Gerber software
    21 June 2005 at 09:52
    Could you maybe try reducing the size of the file in Corel?
    I have GA 6.2 and it sucks out loud at both importing & exporting.
    I know that the image must be black & white to import into GA.
    (at least on my version)
  • Dave Bruce
    21 June 2005 at 11:22
    I imported into Corel Exported as eps to Signlab and it cut no problem. There are a lot of cut lines through the letters etc that you need to sort out.
  • Tecnicasigns
    21 June 2005 at 12:00
    thx for the help. i havent used advantage much .i’m used to signlab, but i dont have it here. i knew it would have no problems cutting the file.
    wish i had signlab 🙁 .
  • Dave Bruce
    21 June 2005 at 12:16
    I have the basic Signlab package.
    (mod-edit) admin@uksignboards.com
    please keep items for sale in the buy, sell, swap forum
  • Angel
    22 June 2005 at 20:21
    The problem is Gerber advantage thinks they are printable items and not set for cut, the way I got around it on Gerber advantage was to use the outline tool to draw around the logo (about 0.1 mm) then delete original logo and you will be able to cut from out line.
    On Omega composer you also get this problem but if you select the logo and right click on it – then select fill and stroke from pop up menu – and set them both to none this will turn it in to a cutting item instead of a printing item
    22 June 2005 at 21:43
    Or use the “raster” to vector” command,
    dunno which heading it’s under.
    But again it only works for me with B&W.
  • Paul Franklin
    22 June 2005 at 21:58
    Sitting at a lap top at the moment with Omega 1.56 which runs an Edge II and plotter.
    Imported the EPS ‘rotary’ file in, selected the gear wheel part of the logo, went into the arrange menu and put ‘cuts on’. Then from file menu output selected. From the plotting program you can then go to the view menu and select view cut. This shows the gear wheel, which I assume is what will will be cut. Haven’t got a plotter to test this out on at home, but will try this out when back in the office and let you know, although I’m sure we’ve used eps files from brandsoftheworld before.
  • Gordon Forbes
    23 June 2005 at 16:21
    The thing that I find with all these files from ai or web sites is that they need to be welded in signlab to stop extra cuts It seems to see the path as an extra cut line inside and out.
    not much help to you I know just thought I would mention it anyway.
    Goop.
    23 June 2005 at 18:23
    another thing refereing to DaveBruce comment.. if you export corel and import GA or similar and your text has a line going through it then one way is to
    From Corel, “Covert the Curves” and the “Break Appart”, as long as there is two shapes then its fine. Export AI then import into sign package.. no issues then
