Home Forums Software Discussions General Software Topics importing bitmaps
  • importing bitmaps
    Posted by Ryan Fairweather on 1 December 2006 at 13:21
    I’m getting an error message when trying to import an eps file that contains bitmap images (photos). The file contains about 20 photos and therefore lots of nodes – could this be causing the problem? It exports normally but comes up as an error when trying to import again. Can anyone help as I need to import the file as an eps to make changes on it? Thanks!
    Shane Drew replied 19 years ago 8 Members · 15 Replies
  • 15 Replies
  • George Elsmore
    1 December 2006 at 13:26
    whats the error message?
  • Ryan Fairweather
    1 December 2006 at 13:44
    ‘an error occurred whilst importing the file….the file cannot be opened.’
  • George Elsmore
    1 December 2006 at 13:48
    I am not teaching you to suck eggs but are you using the PS, PRS, EPS dropdown to import?
    G
  • Ryan Fairweather
    1 December 2006 at 14:32
    Chris think its to do with the file size, nearly 2GB!!! 😮
    Trying to find a way of compressing the file.
  • David Rogers
    1 December 2006 at 14:41
    If you are trying to import it as a vector EPS – the bitmaps will cause a ‘does not compute..error..error’ as it’s no longer a vector file.
    Signlab etc. totally freaks out if you try it! Just tried this…see if it’ll import as an EPS but ‘CONVERT TO BITMAP’.
    If you have access to the original program it was created in then you’re in with a shout.
    Photoshop should be able to import the whole file, but will parse/render it as a bitmap meaning you’ve lose all the vector info & embedded test.
  • Ryan Fairweather
    1 December 2006 at 14:46
    Just exported it as an CMX file and it seems to have worked but strange that its never done it before?
  • Andy Gorman
    1 December 2006 at 15:01
    Just out of interest, what program were you using?
  • Ryan Fairweather
    1 December 2006 at 15:17
    Corel X3.
  • Andy Gorman
    1 December 2006 at 16:12
    I’m having exactly the same problem with X3. A smallish file including 1 bitmap, exported to EPS will not import again. Weird. Same error message as well.
    1 December 2006 at 16:19
    Andy if your problem file is emailable and not private can you send it to me to try.
    alan D
  • Nick Minall
    1 December 2006 at 16:21
    Just tried saving a bitmap to EPS and inporting it works fine on my X3?
  • Andy Gorman
    1 December 2006 at 16:29
    Alan, PM me an email address and I’ll send it over.
  • Rod Young
    1 December 2006 at 21:49
    quote George Elsmore:
    quote ryan fairweather:
    [The program I am using is ] Corel X3.
    I believe George is correct. In CorelDraw, you need to indicate the file type by making a selection within the drop-list. Otherwise, CorelDraw will not necessarily use the import filter that you would have expected.
    Cheers,
    Rod at CADlink
  • Andy Gorman
    1 December 2006 at 22:03
    Yeah but X3 doesn’t have the option of PS or EPS, just EPS.
    The problem as I have experienced is that an EPS export will not import again using the same filter that was used to export it.
    On previous versions, what you say is correct.
    4 December 2006 at 03:15
    quote Andy Gorman:
    Andy, my X3 has ‘EPS, PS, PRN – PostScript’ as an import option
    I’ve just imported a colour photo that I’d exported in eps to my RIP, and it reimported fine as best I can see.
