Home Forums Software Discussions Adobe Software Illustrator contour cutting – which system?
  • Illustrator contour cutting – which system?
    Posted by Richard.Peirce on 25 May 2011 at 21:13
    I’m using illustrator CS3 on a Mac with OSx 10.6.7 as I’m a graphic designer by trade, but wanted recommendations for a starting plotter.
    I know Mimaki do the CG-60SR with a illustrator plugin, but can anyone recommend it or another system with the ability to work with OSx 10.6.7!!
    Maybe the Roland Stika SX, Graphtec Craft ROBO, Graphtec GCC Expert 600mm, Summa D60R FX Vinyl Cutter??
    Fabrice Menard replied 14 years, 6 months ago 5 Members · 5 Replies
    25 May 2011 at 21:39
    scrub these two for a start… they are for hobby craft type setups.
    graphtec, summa, roland etc all good brands… dont go narrower than 610 wide.
  • Richard.Peirce
    25 May 2011 at 21:47
    quote Robert Lambie:
    Thanks Robert, but scrub which two?
    I was thinking about the Graphtec Craft Robo as a starter machine for cutting small logos etc as I only want a desktop option for now, then maybe a larger machine later, but I know what you mean about the 610mm width, most vinyl comes in either a 610mm or 1220mm as I recall?
  • Peter Mindham
    26 May 2011 at 19:39
    My own recommendation would be mimaki with the fine cut plug in for illustrator.
  • Andrew Charman
    26 May 2011 at 22:45
    Hi Richard
    I work from home and I’m running a Summa T1300 from a Mac. I use the free MacSign software that came with the plotter and drop in files straight from Illustrator.
    I would recommend getting a plotter as large as your budget and available space allows, you’ll never look back.
    Andi
  • Fabrice Menard
    28 May 2011 at 19:17
    running a Grapthec CE5000 from Illustrator, works very well and smooth handling.
    I also run a Mimaki CJV30 print/cut machine with FineCut Illustrator plugin.
    I find the graphtec plugin much more handy to work with and time saving than the Mimaki’s one.
