Home Forums Sign Making Discussions General Sign Topics Ideas Needed…..please!
  • Ideas Needed…..please!
    Posted by Martin Pearson on 27 June 2003 at 21:34
    Hi all, I am hoping someone might be able to give me some ideas for a job I have been asked to quote.
    The signs are to be for internal use, there are a couple at A3 size and a couple at A1, blue text on a white background. Apparently there is not a lot of text and it is fairly large.
    The problem is that they want these signs to be vandal resistant and they want some kind of tamper proof fixings to prevent them being removed from the walls. As far as I am aware they are not bothered about graffitti just the signs being broken or pulled off the walls.
    I know there is no such thing as a totally vandal proof sign so I guess I am looking for the next best thing. any help or advice would be much appriciated.
    keith replied 22 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Steve Madley
    27 June 2003 at 21:45
    Why not mask/stencil it and paint directly on the wall(s). I’d like to see them pull that off!
  • Mark Horley
    27 June 2003 at 21:50
    The signs are to be for internal use..they want these signs to be vandal resistant …nice place hey. What i would use is 3 mm white acrylic with blue text applied and a 3mm polycarb face panel double sided together
    framed in panatrim standard (using hex head fixing in the panatrim if necessary)
  • Mike Brown
    27 June 2003 at 22:01
    Martin,
    I’d get some aluminium plates, cover them in vinyl (white) and then cut vinyl lettering (blue), take ‘um down the local body shop and have the lot laquered and baked in the spray oven (probably £30 or so) and then apply a layer of grip-fil builders fixative to the back along with some double sided carpet tape (yes carpet tape – have you ever tried to get this stuff off the floor!) to hold them in place while the gripfil goes off!
    ..only make sure they’re level and in the right place before you leave them! – cus they’re not gunna’ come off!
    more soon
    mikethesign
  • Mark Horley
    27 June 2003 at 22:08
    If you having them laquered….Do a test piece first some vinyls react to the cellulose…
    27 June 2003 at 22:12
    Thanks for the swift replies gents, it gives me a bit more to think about and a rough idea about price.
    Yes Mark it is a nice place, they are for a prison !!
  • Mike Brown
    …good point Mark – though most paint-shops will be using two-pack which is fine – but it would be good to ask first!….[grin]
    more soon
    mikethesign
  • keith
    27 June 2003 at 22:33
    Would Frogjuice not be as good as laquer? It is supposedly designed to be put on vinyl.
